February 5, 2012, 20:31 |
Wind Turbine Fluent setup. Is it correct?
Rep Power: 14 |
Dear all,
I am trying to simulate the NREL Phase VI experiment. Here is the setup I have done: 1) General 2) Cell zone conditions I am treating the whole mesh as a whole Single Moving Reference Frame 3) Boundary conditions a) inlet - velocity The frame is absolute, right? Plus I am not sure what to put in the initial pressure gauge value. I only know the velocity value. b) Blade/rotor The blade is set a rotating wall c) Far field Note the difference in the frame. For the far field I have used absolute frame ( as specified by the user's guide) d) Outlet: pressure outlet with 0 gauge pressure 4) Solution initialization Is the reference frame correct? To conclude, the things I am not really sure about are: With this setup, the far field is affecting the whole flow because is set as wall, how can I set it to not influence the far field, something like open atmosphere or maybe a free-shear wall? Have I set the Moving refererence frame correctly? And what about the initial gauge pressure at the inlet bc? Any help is greatly welcomed as I am a bit stuck and would really need some experienced help. Thanks so much, Federico Last edited by federvo.mala; February 7, 2012 at 08:52. |
February 6, 2012, 17:00 |
3 Questions for you
Rep Power: 15 |
Dear Federico,
According to your questions, With this setup, the far field is affecting the whole flow because is set as wall, how can I set it to not influence the far field, something like open atmosphere or maybe a free-shear wall? A: As I know, outflow is good option. Conceptually, it just let the flow go out. Have I set the Moving refererence frame correctly? A: To my limited knowledge, it is correct. I tried it in a turbine simulation in aircraft engine case before. And what about the initial gauge pressure at the inlet bc? A: No idea on this one. After reading your thread, I have 3 questions: 1, I can not see the Fig.1; 2, Where did you get the mesh file for the NREL wind turbine? Is there any open source for that? 3, Why do you want to use wall roughness = 0? Are you assuming that the wind turbine is pure smooth? best, Alan |
February 7, 2012, 08:49 |
#3 | |
Rep Power: 14 |
Dear Alan, First of all thanks for your reply. 1. I will upload fig.1 again although it's not important at all. 2. I built the geometry on solidworks and then created the mesh on ICEM CFD. It is an unstructured mesh with prism layers around the blade. I can give you the geometry if you want. 3. I set the blade as no slip. I though this would be only straightforward option. Here some other questions for you: 1. What bc shall I use for the outlet? Do you think that pressure outlet at 0 pascal would do the job? If you need any more info regarding the NREL let me know. Thanks, Fred |
February 7, 2012, 12:17 |
Rep Power: 15 |
I always try the 'Outflow' first. You may try it to see if there is any problem like 'reversed flow'. If no, you can use 'Outflow' for simplicity. To my experience, I use 'Pressure Outlet' only when I come across unexpected 'reverse flow' problem. Hope this helps. ^_^
Alan |
February 7, 2012, 16:25 |
#5 | |
Rep Power: 14 |
and you said outflow for the farfield too? I have tried giving it 'velocity-inlet' with the same value as the free-stream velocity, with the difference that instead to 'normal to the boundaries' I put it parallel to the boundaries. It seems to work too but it may be wrong too :S Thanks |
February 7, 2012, 18:07 |
Rep Power: 15 |
^_^ I tried that to deal with unexpected 'reversed flow' issues before. It helps.
Alan |
February 8, 2012, 22:33 |
Rep Power: 14 |
February 8, 2012, 23:07 |
Rep Power: 15 |
February 8, 2012, 23:29 |
#9 |
Rep Power: 14 |
March 24, 2012, 03:40 |
#10 |
john doe
Dear Federvo,
I am trying to do this same simulation in Fluent but am also stuck. Did you get yours to work? If so, then could you please advise me on how you changed yours from the pictures you have shown above? Also could you please advise me on which turbulence model you used and what discretisation schemes you used? Thank you. |
March 25, 2012, 22:22 |
Blade B.c
#11 |
mohamed khedr emam
Rep Power: 14 |
Hi All
I also asking about the Blade B.c why federvo set the Blade >> rotating wall (relative to adj.) instead of setting it "stationary" (the default in rotating reference frame, that walls rotate with the grid, and hence are moving.) thanks |
March 27, 2012, 22:36 |
#12 | |
Abdulqadir Aziz
June 2, 2012, 07:31 |
#13 |
monaya flower
Rep Power: 13 |
Dear Federvo,
1- i think that the far wall must be symmetry in the bc 2-in MRF you should use relative velocity formulation 3- for the blade condition i think it is right i want to ask about why you use intemittency , k and omiga rather than intenesity and viscosity ratio and if you get accurate result how did you calculate the power extracted from the wind turbine thank you |
June 9, 2012, 20:02 |
#14 | |
Rep Power: 14 |
1 - yes you are right. Changed to symmetry in my final model. 2 - probably right, but I always used SRF 3 - I indeed used k-w with intensity and viscosity ratio specs. I first extracted the torque from Fluent and then calculated power (available) via a simple formula.... What are you working on? Best, Fred |
June 11, 2012, 18:27 |
#15 |
monaya flower
Rep Power: 13 |
Hi
I 'm doing numerical simulation of shrouded wind turbine . and i can't calculate the torque . I know that torque would be calculated from report - moment , but i can't specify x,y,z coordinates correctly. can you help me ? what moment i should take if the rotating axis is x ? why did you use SRF rather than MRF . |
June 15, 2012, 07:30 |
#16 |
Rep Power: 14 |
You should put '1' on the x axis and leave '0' for the other axis.
For a horizontal axis SRF is fine (based on literature) and suggestions. Although for a vertical one things are different. |
June 15, 2012, 12:13 |
#17 |
monaya flower
Rep Power: 13 |
Hi Federvo
thank you for your reply . first Are you sure about using SRF ? cause i read the literature about HAWT and they were used MRF . if you used SRF, what is in your opinion bc should i set to get good results? |
June 15, 2012, 14:10 |
#18 | |
Rep Power: 14 |
Velocity-inlet Pressure-outlet Far-field (semi circular face) = Symmetry Plane faces of the domain = periodic Blade = as shown in the pics above Fred |
June 18, 2012, 00:59 |
#19 |
Rep Power: 14 |
I have a similar question here. I had the mash which made in OpenFOAM and converted it to the mesh type for Fluent. In OpenFOAM, there are two kinds of mesh, one part, the outside cylinder, is static mesh and the other part, the wind turbine inside the smaller cylinder, is dynamic mesh, which is rotating. When I tried to run this case, it did not work. The case only runs in the initial second and can not run for more seconds. The wind turbine can not rotate at all. I am wondering whether I need to redefine or reset up the dynamic mesh. I have no idea how to fix this. Could anyone kindly give me some advice? Any advice would be helpful. Thank you. |
June 30, 2012, 20:44 |
direction
#20 |
Sarah4
Rep Power: 14 |
Hello Federvo
I am wondering why your flow direction is -1 for "Y" direction, while your rotational direction is +1 for "Y". I can see from your picture your turbine rotates +Y, then flow direction (from inlet to outlet) should be +1. Am i right? Or i missed something? Thanks. |
Display Modes | |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
Torque of wind turbine simulation | caohan | FLUENT | 8 | August 12, 2014 00:01 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 18:33 |
Virtual Wind Tunnel in FLUENT | ND | FLUENT | 0 | April 7, 2006 08:43 |
