Solution not converging, but oscillating residuals around a constant value
Old   February 7, 2012, 06:29
Default Solution not converging, but oscillating residuals around a constant value
Irene
Irene is on a distinguished road
Hi Fluent users,
I am a new fluent user and I am analysing an impingement system for a vane internal cooling passage, using a realizable k-eps model.
I started using a incompressible ideal gas, the solution converged without any problems but the calculated density was completely wrong, so I changed the material as an ideal gas. Now my solution doesn't converge anymore: all the residuals oscillate around a constant value, and in particular the continuity residuals oscillate around a value which is far from the convergence criteria one.
I tried to change the under relaxation factors (it dumps the oscillatins but it doesn't improve the convergence), to use a finer mesh and to use the fluent mesh adaptation tool but without any results.
Can anbody help me?
Cheers
Irene
Irene is offline   Reply With Quote
Old   February 7, 2012, 11:21
gghazal is on a distinguished road
It is difficult to judge from the few information you gave
What is the pressure and velocity value at the injection system (or maximum pressure in the system) ? Do you have good values of y+ ? Did you check the quality of your mesh ?
Below are a few things you could try :
- Using the density based solver
- start with a lower mass flow (or velocity or pressure) inlet and increase it gradually
- Start by an inviscid flow then add turbulence
GG
gghazal is offline   Reply With Quote
Old   February 7, 2012, 11:55
Ali
Hybrid is on a distinguished road
I think your case is transient! not steady-state.
Hybrid is offline   Reply With Quote
convergence issues, oscillating residuals
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 08:20
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Accuracy and convergence pawan1989 FLUENT 5 April 15, 2010 17:17
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
