February 8, 2012, 09:24 |
How do I define a volume in post-processing?
Rep Power: 17 |
I'd like to calculate the concentration of a UDS in a small volume of my domain during post processing. It seems I can do it over a plane, but I'd like a volume, as it's more accurate.
Do you if this is possible? Regards, |
February 8, 2012, 10:39 |
Try this: adapt->region-> "set your region and just mark it; do not adapt" grid->separate->cells ..... separate your new zone Now you can do post-processing over this volume in both "report" or "solve->monitor->volume" Bests,
Amir |
February 8, 2012, 10:45 |
Rep Power: 17 |
Thanks Amir. Very helpful.
Do you know if it is possible to do this via TUI? I have found the commands for defining my region: Adapt -> Mark-inout-hex but this region does not appear in the separate cells list via TUI... What are your thoughts? Regards, |
February 8, 2012, 10:52 |
#4 | |
Bests,
Amir |
February 8, 2012, 11:14 |
#5 | |
Rep Power: 17 |
I tried mesh modify-zones sep-cell-zone-region but the zone hexahedron-0 is not on the list. Could you try this and see? Regards, |
February 8, 2012, 14:34 |
#6 | |||
your procedure is right but at last you have to specify the IDs carefully. first you have to specify the main zone ID from which you want to separate something: Quote:
then enter the registered ID here: Quote:
adapt->manage-> "Register info/Reg ID" (right side of the panel) That's all. Bests,
Amir |
How to define a volume from a line in Gambit | costa | FLUENT | 1 | January 30, 2007 11:55 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
help: define volume of fraction using UDF in VOF | gogo | FLUENT | 0 | January 17, 2006 15:58 |
define the fluid volume | nessi benishti | FLUENT | 0 | August 2, 2005 16:57 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 20:51 |
