Is my mesh correct
Old   February 10, 2012, 12:23
Default Is my mesh correct
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i'm trying to simulate a flow around seven pitot tubes in a row, i have joined below a screenshot of my mesh, i tried to refine as much as possible next to the pitot tubes as you can see. i get a very big shock wave in front of them at mach=1.5. wich i think is normale. my boss disagree. the source of the problem may be the mesh wich is too refined and non uniforme. can somebody give his opinion on this ?
Thank you very much in advance
diamondx is offline   Reply With Quote
Old   February 10, 2012, 13:22
Far
Sijal
Did you try the SST model and what is the y+ on pitot tubes. Keep Y+ around 2-10.
Old   February 10, 2012, 15:00
diamondx's Avatar
Ghazlani M. Ali
I dont really know what Y+ means as i just got into CFD. i do remember i read about it in a tutorial of an airfoil in fluent. But i didn't get the idea.
Below is a screenshot of Y+ by fluent, is it ok ??? i can see blue region wish problably not good ???!!! i dont now why since the mesh is just a simple quad mesh !!
thank you so much for you help
Old   February 10, 2012, 15:04
Far
Sijal
Y+ should not be less than 0.1. This will seriously affect the solution.
Just google the paper of Menter on SST model applied to flat plate for different yplus values.
Old   February 10, 2012, 16:12
diamondx's Avatar
Ghazlani M. Ali
Im trying change to a new mesh. Below you can see a picture of two pitot tube.
In order to get a good value of Y+. i need to refine as mush as possible betwenn the two pitot tube. as you can see below. i tried a linear mesh law of 8, i know it's not enough. what mesh law do you suggest and how much node number can i put there. (am using a cluster that means that i dont really worry about the time of computing)
Thank you very much
Old   February 11, 2012, 01:49
Far
Sijal
here you can find the details http://www.cfd-online.com/Forums/ans...ning-mesh.html
Old   February 13, 2012, 14:36
diamondx's Avatar
Ghazlani M. Ali
hy there,
Here i'm back with a new mesh , less refined but more uniform. But i still get a too low Y+ like the other one no matter how much i refine or coarsen the mesh. i'm lacking ideas i spent a hole week-end looking for a good documentation about y+.
How can i get a good Y+. sorry if i'm too demanding but i' really stuck !
Thanks in advance
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
What's the correct unstructured mesh procedure Nick R ANSYS Meshing & Geometry 3 January 12, 2011 18:40
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
Converge in Dense meshe, Diverge in less mesh, but correct answer in less mesh!?!? arash_7444 FLUENT 0 December 23, 2009 13:22
