December 11, 2011, 05:32 |
Fluent + ansys meshing dif regions
#1 | ||
Kevin Van Looveren
Rep Power: 14 |
I'm modelling the flow over a fin with louvers and added an inlet and outlet region with different meshing.
I did this by adding a frozen geometry infront and gave them a seperate automatic method in ansys mesher (as shown in http://www.youtube.com/watch?v=RELLrEJ9chg starting 9:45). The mesh looks good in ansys mesher but when I open fluent I get these errors: Quote:
However it seems I'm having the same issue with the interfaces between the outlet region and the actual fin region. But there I can only chose between: *fan *interior *porous-jump *radiator *wall It also has a shadow zone on the same places (I presume one due to the face of geometry 1, other of geometry 2) I figured interior would be suitable, but can't change it as it spouts the following error: Quote:
(hex in inlet/outlet, tet in actual studied geometry)? |
December 13, 2011, 05:13 |
Kevin Van Looveren
Rep Power: 14 |
Or perhaps a better question:
What is the proper way one makes different regions for different meshes from one geometry ? (if making them multiple frozen geometries isn't sufficient) |
February 13, 2012, 08:16 |
Kevin Van Looveren
Rep Power: 14 |
ok so i managed to get rid of the flow boundary errors for now by removing the nozzle (part was also made wrong, it seems, in ansys geometry)
The only problem remaining is the interfaces between the inlet and outlet regions. Does anybody know how I can resolve this? Or perhaps the standard way of making multi-regions (seperate mesh types) ? I'll post a pic of it when I get back home. Last edited by kvloover; February 13, 2012 at 08:38. |
February 13, 2012, 09:19 |
Kevin Van Looveren
Rep Power: 14 |
and seems to be fixed (for now):
forgot two things - make the added parts fluid (default to solid) - make the parts into one multibody part (takes care of the interfaces) |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Meshing In Ansys Workbench For Fluent (Refinement) | FAU_OceanEng | FLUENT | 0 | May 31, 2010 17:12 |
Urgent help needed- FLUENT to ANSYS | Omer | Main CFD Forum | 3 | September 18, 2006 10:24 |
Hot News: Ansys Buys Fluent | Jonas Larsson | Main CFD Forum | 23 | February 22, 2006 17:12 |
