the "continuity" Residual
Old   February 11, 2012, 06:09
Default the "continuity" Residual
aymen harrabi
ay.harr is on a distinguished road
Hallo every body,
I am running a laminar simulation with Fluent. the residuals window shows that all my parameters are fluctuating around a value which is smaller 10-3 only the continuity residual which is fluctuating around value smaller than 10-01. can I say that my Simulation has been converged? and what is this continuity residual?
thanks for help
Regards
ay.harr is offline   Reply With Quote
Old   February 13, 2012, 13:00
Dustin
DungPham is on a distinguished road
Originally Posted by ay.harr View Post
Hallo every body,
thanks for help
Regards
10^-3 ( default in Fluent and it can be change ) value is convergence criterion ( that we desire ) and i think that 10^-1 is so high ! .
Did you run " First Order Implicit" in the " Transient Formulation" ?
DungPham is offline   Reply With Quote
Old   February 13, 2012, 18:58
cfdnewbie
cfdnewbie is on a distinguished road
The density residual gives you the error in your RHS of the continuity equation. 10 to the minus 1 seems to be pretty high, check your boundary conditions, often they prevent further convergence in density!
cfdnewbie is offline   Reply With Quote
Old   February 14, 2012, 03:29
Emre G
emreg is on a distinguished road
you can try it with first order discretization settings.
emreg is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
