February 22, 2010, 08:19 |
how to couple VOF and DPM ??
sed
Rep Power: 16 |
Hello all
I have simulated a case with VOF model for getting interface of water and air. Now I need to introduce (Inject) some solid particles into the mixture of high speed water and air (Gas-liquid-solid). 1. Can I now switch to Discrete Particle Model directly from VOF 2. How to couple them (DPM & VOF) together in FLUENT ? As I have seen in the FLUENT manual there are no restrictions on using VOF model in combination with DPM...... thanks
Life is not always converging ... but u can relax |
February 22, 2011, 13:32 |
vof+DPM
raj
Rep Power: 16 |
Hello cfdiscool,
I am facing same problem as yours. I am trying to introduce solid particles into stream of liquids. I have to use VOF to study the interference between the liquids. At the same time i have to study the behavior of these solid particles introduced. If you found the way to do it , please guide me. Anyone working on this please help me. I have read other threads but I still need some info on this. Thanks in advance.! |
September 5, 2011, 02:18 |
Vof+dpm
Hello all,
It's possible to couple vof model and dpm model at the same time in Fluent. but you have to choose the primary fluid wisely. Best, Sajjad Bigham |
September 5, 2011, 10:20 |
Harpreet
Rep Power: 14 |
i tried Eulerian model and it worked fine for me.
March 15, 2016, 12:49 |
Vedant Dwivedi
Rep Power: 10 |
March 15, 2016, 12:52 |
Cees Haringa
Hi Ved,
In which of the phases do you need the particles to exist? in only one, or in both? The Eulerian multiphase model has very different purposes than VoF, so I would not directly consider that. |
March 16, 2016, 00:11 |
Vedant Dwivedi
Rep Power: 10 |
Actually i am simulating water droplets (secondary phase) in air over cylindrical surface in DPM model (to calculate drag and particles tracking ) which then i want to couple with euler water film model to calculate water film thickness.
coupling, dpm, vof |
VOF and DPM together | xiana | ANSYS | 0 | October 28, 2009 11:52 |
DPM or VOF model? | Benjamin Behey | FLUENT | 2 | December 2, 2008 18:37 |
VOF and DPM | marek | FLUENT | 1 | September 30, 2008 08:55 |
Possibility of combining DPM and VOF | Kelly | FLUENT | 0 | September 24, 2007 16:12 |
DPM model coupled with VOF | Doug | FLUENT | 0 | March 1, 2005 16:37 |
