Animation crash when using ppm image
Hi there,
In Fluent 13 I automatically get a crash when reading or trying to export an animation made of ppm images. The program "cx1300.exe" crashes and Fluent quits. The ppm images stored are fine when I read them with a photo software but Fluent can't handle them to get a movie. It can only works on Metafiles or Memory. I tried with various meshes, serial and parallel. I really need to use ppm to store hundred of image files. Did some of you experienced the same problem ? Is there a possibility to use a post processing soft to convert the ppm image generated into a usable MPEG file ? Thanks Charles |
