The oscillation of scaled residuals is very big |
February 16, 2012, 21:00 |
zhangqing
Rep Power: 14 |
My settings is as follows:
Models: Mixture、Realizable k-e、Standard Wall Functions General: Pressure-Based、 Transient Phases: Drag coefficient——Schiller-naumann Surface Tension——0.072N/m Boundary Conditions: gas_inlet: velocity_inlet: outlet: Pressure_out Solution Method:PISO every time step the result is converged, but the oscillation of scaled residuals for k and epsilon are very big,I don't know how to solve the problem. Thank you very much for your help. |
Difference between scaled residuals and... | Dieter | FLUENT | 0 | April 28, 2006 17:52 |
Oscillation of residuals in DPM (Ergent need!) | yooceframandi | FLUENT | 1 | February 28, 2006 06:46 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
Scaled residuals | Raja | Siemens | 1 | May 31, 2001 04:13 |
