Home > Forums > FLUENT
turbulence viscosity ratio limited to 1 exp 5
Old   February 21, 2012, 11:17
Default turbulence viscosity ratio limited to 1 exp 5
tichaona
tichaona is on a distinguished road
Hi colleagues
When I run simulation using a 1m/s wind, I dont get the turbulence viscosity ratio limited to 1 exp 5 in my solution. I get the message after changing the wind speed to 3m/s. What causes this.
I will appreciate any contribution.
Regrads
T.K
tichaona is offline   Reply With Quote
Old   February 21, 2012, 12:28
Default Re
Domenico
doronzo is on a distinguished road
hi
your Re number increases if you have a higher velocity, which probably means that the difference between your turbulent viscosity and molecular viscosity, or their ratio, also increases.
regards
doronzo is offline   Reply With Quote
Old   February 21, 2012, 23:59
federvo.mala is on a distinguished road
I have been also encountering that problem. What I do, although I am not sure it's correct, I simply increase the value of the turbolent viscosity in 'solutio controls'---> 'limits'.
federvo.mala is offline   Reply With Quote
Old   February 22, 2012, 15:09
Domenico
not totally sure, but I think you can increase that value, which is the limit of your solution, in which case you sometimes avoid that ''problem''
Old   February 24, 2012, 07:15
delaneyluke is on a distinguished road
Increasing the solution control limits won't solve your problem, it will just stop giving you warnings. The reason your turbulent viscosity goes up is more of a numerical problem. Try reducing your relaxation factors.
Regards
Luke
delaneyluke is offline   Reply With Quote
Thread Tools
Trackbacks are On
turbulent viscosity limited to viscosity ratio... frank FLUENT 19 December 15, 2015 23:54
"turbulent viscosity limited to viscosity ratio" olivier FLUENT 11 October 10, 2015 05:49
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Problem with turbulence viscosity ratio k.baker FLUENT 21 May 1, 2008 15:21
turbulent viscosity limited to viscocity ratio of gayatri FLUENT 2 February 27, 2007 13:22
