February 22, 2012, 06:44 |
2.5D Remeshing
Felice
Rep Power: 15 |
Hi all,
I have 2 dynamic zones divided by an internal boundary. I have a swept mesh that goes trough both zones. The target surface is meshed with triangles only. I need to update the mesh after the motions of the external walls. I select the target surface and I set it like dynamic (deforming) with 2.5D remeshing and smoothing enabled. Than I select the target surface and I set it like dynamic (deforming) with only smoothing enabled. Now, what are the correct settings for the internal boundary that lies between the target and the source surface? |........zone1..........|........ zone 2........| --> sweep direction source................interior................targ et Regards F |
Remeshing with User Defined Options | ChristianF | CFX | 2 | September 24, 2014 09:19 |
2.5D simulation in CFX-pre | yvonne | CFX | 5 | November 10, 2011 04:34 |
Bugg in Remeshing in 3D - Any Fluent Wizards ?? | Amr | FLUENT | 1 | November 1, 2011 04:04 |
Dynamic Grid Remeshing causing Divergence? | Andrew Wick | FLUENT | 0 | January 23, 2006 18:39 |
Dynamic_Mesh for large mvt : remeshing parameters! | caloggero | FLUENT | 3 | May 6, 2003 05:44 |
