Home > Forums > FLUENT
1/7th power law
Old   February 29, 2012, 17:01
Default 1/7th power law
Gamb1t is on a distinguished road
I am trying to work out static pressure distribution across an orifice. i have plotted it and noticed that since the upstream pipe length is not long enough the flow is not becoming fully developed(turbulent).
I looked at how it was meant to be modelled and it says inlet boundary condition with 1/7th power-law was used. i know this has something to do with User defined functions which i am unfamiliar with. Do i have to do some programming or something? or is it a setting within fluent.
thank you for any help.
Gamb1t is offline   Reply With Quote
Old   February 29, 2012, 20:51
I have found a 1/7th power law but when i interpret i get the following error: line 9: parse error.
I think it means the line DEFINE_PROFILE(x_velocity,t,i) but i dont know why that is since i copied and pasted it from the UDF manual. i have changed the value for YMAX and UMEAN. Any help would be gladly appreciated. Thank you.
/*#include "udf.h"*/
#define YMIN 0.0 /* constants */
#define YMAX 0.05
#define UMEAN 20.0
#define B 1./7.
#define DELOVRH 0.5
real y, del, h, x[ND_ND], ufree; /* variable declarations */
face_t f;
h = YMAX - YMIN;
del = DELOVRH*h;
ufree = UMEAN*(B+1.);
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y = x[1];
if (y <= del)
F_PROFILE(f,t,i) = ufree*pow(y/del,B);
else
F_PROFILE(f,t,i) = ufree*pow((h-y)/del,B);
end_f_loop(f,t)
Old   March 1, 2012, 01:38
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
uncomment the first line #include uds.h.
Take in mind that this udf will work for 2d axisimmetric problem.
Daniele
ghost82 is offline   Reply With Quote
Old   March 1, 2012, 14:09
Thanks for the reply Danielle. It worked fine. Since the model is axisymetric, does it mean YMAX is the actual diameter or half of it as it is modelled.
Thank you
Old   March 1, 2012, 20:03
Default Axial velocity with parabolic profile
Is there a udf that i can use to specify an inlet boundary condition for laminar flow that will give axial velocity with parabolic profile.
Thanks.
Old   March 2, 2012, 07:33
ghost82's Avatar
Daniele
Thank you
Hi, YMAX refers to your axisymmetric grid so it's half diameter.
Daniele
Thread Tools
Trackbacks are On
Non-Newtonian Power Law for Viscosity John FLUENT 16 September 12, 2015 06:18
Non-Newtonian Flow: Power law (2D BFS) hellouch FLUENT 3 April 21, 2009 03:03
about one seventh power law in CFX Eric CFX 3 January 10, 2007 08:16
power law flow through porous media Francesca Chiusa FLUENT 1 November 3, 2006 15:30
Non newtonian power law model in pipe annulus Poly FLUENT 0 March 24, 2005 16:12
