-   -   [FLUENT/ICEM] Transition modeling (http://www.cfd-online.com/Forums/fluent/98040-fluent-icem-transition-modeling.html)
robboflea March 1, 2012 15:04
2 Attachment(s)
Hi all,
I'm trying to model transition on a 2D turbine airfoil by using the mesh in the picure. Basically two of the blocks in the boundary layer have been moved to a "LAMINAR" part in ICEM while the remaining part is in the "FLUID" part. The idea is to have the laminar zone to be set-up as a "laminar zone" in the cell zone conditions tab in Fluent, while running the simulation with fully turbulent Spalart Allmaras model. (I know I could use a transition model but I really want to try to tackle the problem in this way and I read somewhere in the forum that it was possible to do it but it was not explained well how).
All mesh check in ICEM works fine and I can import the mesh successfully in fluent. together with the normal inlet, outlet, blade and periodic boundaries I get also a boundary between the turbulent and laminar zones (set as an internal boundary) and a laminar wall boundary on the blade which I set as a normal wall.
The problem is that I can initialize the solution but I cannot start the solver. Using the same exact mesh (with the laminar patch being part of the fluid and the solver fully turbulent) I could run it without problems. Normally I used fmg initialization and then I run the case. Now when I run the fmg i get the following:
>> Reordering domain using Reverse Cuthill-McKee method:
zones, cells, faces, done.
Bandwidth reduction = 159/159 = 1.00
Done.
Creating multigrid levels...
Grid Level 0: 49126 cells, 98574 faces, 49900 nodes; 2 clusters
Grid Level 1: 12217 cells, 49704 faces, 0 nodes; 2 clusters
Grid Level 1: 12217 cells, 27317 faces, 0 nodes
Grid Level 2: 3532 cells, 27978 faces, 0 nodes; 2 clusters
Grid Level 2: 3532 cells, 9694 faces, 0 nodes
Grid Level 3: 1165 cells, 18093 faces, 0 nodes; 2 clusters
Grid Level 3: 1165 cells, 3500 faces, 0 nodes
Grid Level 4: 391 cells, 12094 faces, 0 nodes; 2 clusters
Grid Level 4: 391 cells, 1238 faces, 0 nodes
Grid Level 5: 135 cells, 8227 faces, 0 nodes; 2 clusters
Grid Level 5: 135 cells, 450 faces, 0 nodes
Done.
FMG: Converge FAS on level 5
FMG: Converge FAS on level 4
FMG: Converge FAS on level 3
FMG: Converge FAS on level 2
FMG: Converge FAS on level 1
0.->1.->2.->3.->4.->5.<<<<<
Error: Divergence detected in AMG solver: nut
Error Object: #f
Am I doing something wrong in the mesh generation or in Fluent setup?
Sorry for the long post.
Rob
robboflea March 7, 2012 05:35
Apparently it was a Fluent bug. When restarting Fluent the day after everything was working fine.
If somebody needs help with this strategy for transition modeling I'll be happy to help.
Rob
