Home > Forums > FLUENT
Problem in meshing a moving core
Old   March 6, 2012, 10:34
Default Problem in meshing a moving core
shashankshankar is on a distinguished road
I am analyzing the flow in a pipe which has a self propelled plate (solid) inside it. In GAmbit applying the coutte flow technique, I created a 2D model of it. The problems I am facing are
1. When I am declaring plate as a solid continuum and giving it a velocity in one direction, no result is coming
2. When I am declaring the plate as a face with 4 walls and giving the whole face a velocity, the flow is occuring inside the plate!! and the gap between pipe and plate has no velocity!
Can someone please guide me in this? I am new to both gambit and Fluent
shashankshankar is offline   Reply With Quote
Old   March 6, 2012, 10:48
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
in gambit, you need to split your pipe with your solid.
Your plate should appear as an hole (>> no fluid flow through the plate)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem with segment surface and meshing Silmaril ANSYS Meshing & Geometry 1 October 13, 2011 16:42
Moving Volumes Problem johngsl FLUENT 3 August 5, 2011 13:19
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Moving Mesh Problem Rashad FLUENT 0 August 28, 2006 04:31
moving boundary problem Andrea Panizza Main CFD Forum 1 February 26, 2002 16:54
