March 6, 2012, 12:29 |
udf doesn't work
Hi dear
I am trying to model solid carbon particals inside a cylinder using euler-euler model in fluent .The gas phase is o2 n2 co2 and the solid phase is c(s).In this simple model there is only one hetergeneousb reaction c(s) +o2 >co2. A udf is used to define the rate of this reaction. First the rate of the reaction is assumed to be kinetically controlled and this gave a result. Then it was assumed that the reaction is controlled by kinetics and diffusion of oxidant o2.The udf was compiled but it doesn't give results. So what is the wrong with this udf (attached). your response is so appreciated, Many thanks |
UDF using c_face_loop(c,t,i) | frederic | FLUENT | 3 | January 16, 2017 23:17 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
udf - c++ compiler does not work | Matthias | FLUENT | 1 | January 9, 2009 00:44 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
Will the UDF work?? | H.S.Fang | FLUENT | 0 | December 27, 2001 21:21 |
