Species mass flow inlet
Old   August 5, 2011, 11:46
Default Species mass flow inlet
Manuel Lorenz
lorenz is on a distinguished road
I have a problem with the boundary condition mass flow inlet. I have enabled the Species model and use a mixture of air and h2o, stationary. I want to model a room with air in/and outlet -> no problem. Air with a vapout content of 0.1% coming from the inlet
Additionally I want to model the vapour production by a human inside. So I have one surface with boundary condition mass flow inlet m=1.3e-5 kg/s Species h20=1. So only vapour coming out of that inlet. Inlet diffusion is disabled, because I want to keep the defined massflow.
When I run the calculation I get no convergence of the h2O content and parts with "negative" water content, meaning lower then the inlet content. How can I fix this? A UDF? How would it have to look like?
By trying different things i observed some other strange things:
- When I set the massflow from a massflow inlet to zero but have specified a Species concentration for the inlet I still get a relevant Species flow from this surface. This happens even though Species diffusion from inlet is disabled. When I enable Species diffusion from inlet the mass flow inlet becomes unrealistically big (much bigger then for a wall boundary condition with specified Species)
- When i define a wall boundary with specified Species at the border. I expect a netto mass flow from the wall to the volume because of diffusion and convection. This mass flow is visible in concentration profiles. But when I calculate the mass flow with the report tool it is zero. Why?
Thank You for help
Manuel
lorenz is offline   Reply With Quote
Old   August 11, 2011, 06:13
Manuel Lorenz
can nobody help on this topic? I still didn't find a solution...
Old   March 13, 2012, 01:42
Texas
niket shah is on a distinguished road
hey did u done with this work...bcoz I am doing the same kind of the problem...If you want to share your knowledge then reply me back...
niket shah is offline   Reply With Quote
Old   March 15, 2012, 07:26
Manuel Lorenz
I couldn't solve the boundary diffusion inlet massflow. But I modelled the problem now in a different way:
I use a volume source term for the water vapour source instead of boundary inlet. I use a udf for the source to be active only in a defined volume. --> This wirks very well.
mass flow inlet as boundary condition applemango FLUENT 1 March 10, 2010 01:05
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
velocity or mass flow inlet? Silvia FLUENT 1 August 12, 2005 13:55
Mass flow inlet Anshul FLUENT 2 March 4, 2005 00:19
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
