Stagnation Pressure in FLUENT
Old   March 15, 2012, 12:13
Default Stagnation Pressure in FLUENT
Mahindra
mahi007 is an unknown quantity at this point
Hello all
I am doing analysis of flow past circular cylinder. I am stagnation pressure value at different reynolds numbers. I am taking this from Total pressure infront of cylinder XY plot in FLUENT. Am I right doing this?
Also density value and velocity both equal to 1 in my simulation. Looking at experimental values I am getting nearly 0.5 less for every value. Do I need to add 0.5*density*velocity^2 value to pressure to get stagnation value. If not where I am going wrong?
Thanks
Regards
Mahindra
mahi007 is offline   Reply With Quote
Old   March 15, 2012, 14:42
Robert
Kwiaci is on a distinguished road
In FLUENT Total Pressure for incompressible fluids is defined as:
total pressure = static pressure + 0.5*density+velocity^2
Question is what is your methodology of measuring pressure during test? Probably you get there only one component of this equation.
Kwiaci is offline   Reply With Quote
Old   March 15, 2012, 23:38
Mahindra
I mean my simulation values are nearly 0.5 less than experimental values. Experimental values are taken from research journals.
Am I correct taking stagnation pressure from total pressure at front of cylinder?
Old   March 16, 2012, 06:31
Robert
Yes you are. Maybe try to improve mesh in front of cylinder.
Old   March 16, 2012, 09:56
Mahindra
I am already using a finer mesh and drag value for this mesh is close to experimental value. Pressure value is not changing much over refinement. Rest of all parameters are good like seperation point etc..
What can I do now?
Old   March 16, 2012, 10:09
banty
banty is on a distinguished road
Totel (stagnation) pressure remains constant throughout of domain with compressible or
incompressible flow until shock is present in domain.
banty is offline   Reply With Quote
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 14:32
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
How to give pressure inlet in Fluent Vijayaragavan Main CFD Forum 1 December 17, 2007 09:40
pressure outlet BC for Boussinesq with Fluent stephane Main CFD Forum 1 October 20, 2007 07:09
Calculating Centre of Pressure within FLUENT Matt FLUENT 1 March 5, 2006 08:29
