obtaining pressure in postprocessing
Hi , I have a little question.
I'm simulating a single circular cylinder(2D problem), and I want to know the pressure in the wake vortex zone in a single point (downstream at 4 diameter in the x-direction). I want to know how the pressure variate in time and plotting if it is possible. Somebody could help me?. Thanks in advance! |
Yep, it's possible. Follow these steps: 1) create your desired point (probe): surface->point 2) solve->monitor->surfaces select your point and the variable you want to plot/write. (you can toggle on writing or plotting or printing desire data here). Note that you can set vertex minimum or maximum or average in report type panel. Bests, |
