Problem with the animation
I try to create the animation of cooling of a composite material after a heat impulse. I defined the animation and I can watch it in Fluent but it doesn't create a file with it. After I chose MPEG and click write button following message appears: "mpeg_encode param3" MPEG ENCODER STATS (1.5b) ------------------------ TIME STARTED: Sat Mar 17 12:49:36 2012 MACHINE: unknown FIRST FILE: ./temp_1_0000.ppm LAST FILE: ./temp_1_0257.ppm PATTERN: i GOP_SIZE: 12 SLICES PER FRAME: 1 RANGE: +/-8 PIXEL SEARCH: FULL PSEARCH: EXHAUSTIVE BSEARCH: CROSS2 QSCALE: 8 8 8 REFERENCE FRAME: ORIGINAL Input file too small! (./temp_1_0000.ppm) Removing frame files ... done. This is the first time I have encountered sth like this. What might be wrong? |
| All times are GMT -4. The time now is 03:13. |
