How to make a porous media ??
Old   March 17, 2012, 14:28
Question How to make a porous media ??
A7med is on a distinguished road
I'm working Fluent v13 ..
I wanna study the flow inside a porous media ..
but I'm new to the program and I dunno how to define a porous media :/
Can you help with that ?
A7med is offline   Reply With Quote
Old   March 19, 2012, 01:12
Abdul Halim
abdulhalim060189 is on a distinguished road
I'm also having the same problem.
abdulhalim060189 is offline   Reply With Quote
Old   March 20, 2012, 08:04
JP
srjp is on a distinguished road
You need to define the region as a separate fluid zone when you create the geometry, and then in the 'fluid zone' definition in Fluent, you can click on the 'porous' option.
You need to specify the porous zone properties, like porosity and the inertial and viscous resistances.
srjp is offline   Reply With Quote
Old   March 22, 2012, 06:40
delaneyluke is on a distinguished road
Alternately you could approximate your 3d porous zone as a 2d surface and use the porous jump boundary condition, where you specify your inertial & viscous resistances and your media thickness.
Porous jump will not account for resistances in the 3 (x,y,z) directions but consider them to be normal to the surface only.
Regards
Luke
delaneyluke is offline   Reply With Quote
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
Porous Media coupled with internal flow Samuel Andrade FLUENT 2 August 26, 2012 09:43
compressible flow through porous media Chirag2302 FLUENT 0 March 2, 2012 23:13
combustion in porous media burner zuby ANSYS 0 July 27, 2009 02:26
Question for modelling flow in porous media legendyxg FLUENT 9 April 21, 2009 22:24
