BC problem: modelling ground as a porous material |
March 17, 2012, 13:25 |
CH. Lee
Rep Power: 15 |
As shown in the attached figure, ground and well is modeled (axisymmetric) as a porous material using laminar flow, energy equation and some UDF for the porous resistances. There is only one phase (water). Because of ground water flow from the outside boundary, I choose the pressure inlet BC for the outside and bottom boundary (upper boundary is modeled as a wall). : 1 velocity inlet, 1 outlet at well surface. porosity = 1 in the well, porosity < 1 in the ground. Q1: To model the hydrostatic pressure due to the gravity, I checked the gravity box and specified operating density (=0). In that case, I can see a pressure distribution with depth direction. However, if I use 998.2 kg/m3 as the operating density, can I get pressure head through the analysis? Because, in this case, pressure = 0 at the whole domain from the result. [gradient of groundwater flow is calculated in the total head difference in the aspect of groundwater. total head = potential head (due to the gravity, location) + pressure head + dynamic head (in most cases, = 0) ] Q2: For the outside and bottom boundary, I used a gauge pressure = 0 at boundaries. Is that reasonable? I can see many reverse flow faces in this case at the pressure inlet boundary with operating density = 998.2 kg/m3. Also, I've tried to give a reverse pressure to the boundary for the equal pressure in the ground using simple UDF ( (height - location) * 998.2 * 9.81 ). This is for the equal pressure at the boundary to model pressure head. How can I model the pressure which is only due to the pressure head not static pressure? Any suggestions? Thanks Last edited by cryfreer; March 17, 2012 at 18:58. Reason: correcting |
March 17, 2012, 18:54 |
CH. Lee
Rep Power: 15 |
Problem solved using UDF, Thanks
March 19, 2012, 01:14 |
#3 | |
Abdul Halim
Rep Power: 14 |
boundary condition, porous media |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Porous media solving problem | mulfal | OpenFOAM Running, Solving & CFD | 2 | June 23, 2010 05:31 |
Ammonia-liquid modelling. Problem with thermal expansion coefficient. | zhekka | FLUENT | 0 | February 9, 2010 15:06 |
Simple Porous Problem | Abdul | FLUENT | 0 | October 31, 2005 18:30 |
