Which turbulent model is good for a diffuser? |
March 19, 2012, 11:57 |
Rep Power: 13 |
So I placed a duct (diffuser) around my wind turbine, and the air flow is turbulent. So do you guys have any recommendations for which turbulence model should I used, and why?
March 19, 2012, 12:40 |
Rep Power: 13 |
March 19, 2012, 13:00 |
Rep Power: 14 |
Sorry, but that is real basics ... you should understand that, because otherwise you wonīt know how to get a good solution.
http://www.cfd-online.com/Wiki/Dimensionless_wall_distance_%28y_plus%29 |
March 19, 2012, 13:02 |
Ghazlani M. Ali
Rep Power: 28 |
This is what i learned recently, someone please corrects me if i'm wrong:
Y+ is an non-dimentional parameter that determines how refined your mesh is near a wall and therefore how accurate you can be (regarding boundary layer), the more refine the more accurate, small value means good accuracy in general below 10 and not less than 0. There is a tool in cfd-online that allows you to determine the height of the first cell near the wall depending on the Y+ you want. just google Y+ estimator. |
March 19, 2012, 13:10 |
#6 | ||
Rep Power: 14 |
y+ canīt be less than 0 |
How to model a turbulent flow over a cylinder? | Mahbub | FLUENT | 14 | February 10, 2018 11:14 |
turbulent viscosity in k-e model | orlik | Fluent UDF and Scheme Programming | 1 | July 19, 2017 12:27 |
Turbulent combustion error... XiFoam model | achinta | OpenFOAM | 1 | July 7, 2010 08:24 |
k-w turbulent model and inflow boundary conditions | vaina74 | Main CFD Forum | 6 | April 26, 2010 06:03 |
contradicting results of different turbulent model | dani | FLUENT | 0 | July 6, 2004 02:07 |
