March 21, 2012, 23:46 |
FLUENT Parallel Computing
Rounak Manoharan
Rep Power: 14 |
I know this question has been asked in some form already but I have either not fully understood it or it does not apply for my case. Basically, whenever I click ok after I have chosen to parallel compute (on FLUENT) I get a cmd window asking for my account and password (in spite of turning off the firewall). Could you please advise what I need to do to overcome this problem thanks a lot Rounak Last edited by Rounak; March 22, 2012 at 18:10. |
March 22, 2012, 08:50 |
Ghazlani M. Ali
Rep Power: 28 |
same thing happens to me in my university, what i do is type the password i used to log in in that session. If no password is set, like in a personal computer, leave it blank and press enter. But i recall having this problem only the first time i rum the parallel mode, after that the dialog box never showed up again let me know if it worked.
March 22, 2012, 09:02 |
#3 | |
Rep Power: 14 |
I had kind of the same problem. I just added all nodes I could use manually to the file ".ssh/know_hosts" |
March 23, 2012, 04:06 |
#4 | |
Rounak Manoharan
Rep Power: 14 |
Thanks, Rounak |
March 24, 2012, 01:08 |
Problem solved
Rounak Manoharan
Rep Power: 14 |
My friend helped me solve the problem. essentially when you are given an option to parallel or serial compute, you go to the parallel settings and set the MPI type to HP, the cmd window will cease to pop up. Hope this helps for those faced with the same problem.
Rounak |
fluent - udf - parallel |
Parallel Processing Problems Fluent 13 | lstebe | FLUENT | 3 | February 15, 2012 09:54 |
Parallel computing in Fluent 6.3 | Poovanna | FLUENT | 2 | February 18, 2011 09:17 |
Fluent parallel | poovanna | FLUENT | 0 | March 23, 2007 23:22 |
Parallel Computing | peter | Main CFD Forum | 7 | May 15, 2006 09:53 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
