FLUENT Parallel Computing
Old   March 21, 2012, 23:46
Question FLUENT Parallel Computing
Rounak Manoharan
Rounak is on a distinguished road
I know this question has been asked in some form already but I have either not fully understood it or it does not apply for my case. Basically, whenever I click ok after I have chosen to parallel compute (on FLUENT) I get a cmd window asking for my account and password (in spite of turning off the firewall). Could you please advise what I need to do to overcome this problem
thanks a lot
Rounak
Rounak is offline   Reply With Quote
Old   March 22, 2012, 08:50
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
same thing happens to me in my university, what i do is type the password i used to log in in that session. If no password is set, like in a personal computer, leave it blank and press enter. But i recall having this problem only the first time i rum the parallel mode, after that the dialog box never showed up again let me know if it worked.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 22, 2012, 09:02
Zigainer is on a distinguished road
Probably after your first time, the used node is a "known_host".
I had kind of the same problem. I just added all nodes I could use manually to the file ".ssh/know_hosts"
Zigainer is offline   Reply With Quote
Old   March 23, 2012, 04:06
Rounak Manoharan
Hi, it did not work, the message that comes up in the cmd window after I press enter when it asks for my password is: 'MPICH2 is unable to manage jobs using credentials with a blank password'. I never set a password on my laptop. Anyone else have any idea (s)??
Thanks,
Rounak
Old   March 24, 2012, 01:08
Default Problem solved
Rounak Manoharan
My friend helped me solve the problem. essentially when you are given an option to parallel or serial compute, you go to the parallel settings and set the MPI type to HP, the cmd window will cease to pop up. Hope this helps for those faced with the same problem.
Rounak
fluent - udf - parallel
Parallel Processing Problems Fluent 13 lstebe FLUENT 3 February 15, 2012 09:54
Parallel computing in Fluent 6.3 Poovanna FLUENT 2 February 18, 2011 09:17
Fluent parallel poovanna FLUENT 0 March 23, 2007 23:22
Parallel Computing peter Main CFD Forum 7 May 15, 2006 09:53
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
