-   FLUENT (
-   -   Error message (
Prince of Persia March 27, 2012 05:04
Error message
hi all
I am a new user for CFX so I might ask some stupid questions here. Sorry for that.
my question is when I run the simulation...I got the message:
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 1081594 cells
What should I do?
evswbok March 28, 2012 10:49
change the viscosity ratio
drhim86 May 7, 2012 02:15
How we can change viscosity ratio?
How can the viscosity ratio be changed in FLUENT 6.3?
delaneyluke May 7, 2012 02:22
Reduce your under-relaxation parameters.
Which turbulence model are you using?
drhim86 May 7, 2012 02:28
I have used standard k-omega model and unsteady DES
delaneyluke May 7, 2012 03:03
By unsteady DES, do you mean a transient simulation?
1) Try reducing your under relaxation factors
2) Start your simulation with the standard k-epsilon model and later switch to k-omega
3) If your run is transient, then try reducing your time step
drhim86 May 7, 2012 05:45
Done all
Dear Mr. Luke,
As per your recommendations I have tried:
1) reducing under relaxation factors
2) Started simulation with the standard k-epsilon model but observed oscillations persisted
3) By running transient run solution diverged
Kindly acknowledge me with your suggestions
