an error problem for a change of boundary condition
Old   March 27, 2012, 05:39
Question an error problem for a change of boundary condition
tsi07 is on a distinguished road
HI every body,
it's my first time on this forum.
I'm trying to change a boundary condition on a wall to put a velocity inlet but I have some problem when I want to use the adjacent cells of the face thread.
Can Anyone help me, I don't understand what is the problem.
I tried to find the problem, and I think it comes from the "F_C0" command.
The error message that it's appear is :
FLUENT received fatal signal (ACCESS_VIOLATION)
Here is my UDF,
#include "udf.h"
#include "mem.h"
double V_n[ND_ND], V_t[ND_ND], BC[ND_ND], VC[ND_ND];
real K, n, TAU0; /* consistency, power law parameter, limit yield stress for flowing */
real m, Cf, SL; /* regularization parameter, friction coefficient, limit yield stress for slipping */
double vmag, StrainRate, constante, TAUxx, TAUxy, TAUyy, VC_MAG;
double dudx, dudy, dvdx, dvdy; /* derivatives */
face_t f;
cell_t c0;
DEFINE_PROFILE(wall_new_boundary, thread, position)
K=1;
n=1;
TAU0=1;
m=100000;
SL=0.6;
begin_f_loop(f, thread)
F_AREA(V_n,f,thread);
c0 = F_C0(f,thread); /* adjacent cell to f */
vmag=-NV_MAG(V_n); /* magnitude and opposite of normal vector */
V_n[0]=V_n[0]/vmag; /* normed vector */
V_n[1]=V_n[1]/vmag; /* normed vector */
F_CENTROID(BC, f, thread);
NV_D(V_t,=,-V_n[1],V_n[0]); /* tangent vector */
StrainRate = C_STRAIN_RATE_MAG(c0, thread);
constante = K*pow(StrainRate,(n-1))+TAU0*(1-exp(-m*StrainRate))/StrainRate;
dudx = C_U_G(c0,thread)[0];
dudy = C_U_G(c0,thread)[1];
dvdx = C_V_G(c0,thread)[0];
dvdy = C_V_G(c0,thread)[1];
TAUxx=2*constante*dudx; /* stress tensor's xx componant*/
TAUyy=2*constante*dvdy; /* stress tensor's yy componant*/
TAUxy=constante*(dudy+dvdx); /* stress tensor's xy componant*/
VC[0]=(TAUxx*V_n[0]+TAUxy*V_n[1])*(pow(V_t[0],2)); /* stress vector's x componant*/
VC[1]=(TAUxy*V_n[0]+TAUyy*V_n[1])*(pow(V_t[1],2)); /* stress vector's y componant*/
VC_MAG=NV_MAG(VC); /* stress vector's magnitude */
if ( VC_MAG < SL)
F_PROFILE(f, thread, position)=0;
else {
F_PROFILE(f, thread, position)= -VC[0]*(VC_MAG-SL)/(VC_MAG*Cf);
end_f_loop(f, thread)
Thanks for your help !!
tsi07 is offline   Reply With Quote
Old   March 27, 2012, 12:10
Question a simplified issue to solve my problem
Here is a simplified UDF. It has no physical sense but it much more readable.
My problem is that I need to use the adjacent cell of face to chek the velocity there, but when I use "F_C0" command for it I have an error message which is :
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
ANd here is the code :
#include "udf.h"
#include "mem.h"
double VC[ND_ND];
real SL;
double VC_MAG;
double dudx, dvdy;		/* derivatives */
face_t f;
cell_t c0;
DEFINE_PROFILE(wall_velocity_x, thread, position)
	SL=0.6;
		VC[0]=dudx;
		VC[1]=dvdy;
		VC_MAG=NV_MAG(VC);
		if ( VC_MAG < SL)
		else	{
			F_PROFILE(f, thread, position)= VC_MAG-SL;
If anyone have an idea, I'll take it !
Thanks.......
Old   March 28, 2012, 11:21
Default Can I call an adjacent cell with an other way ?
I have no answer up to now.
So I change my question to be helped one day...
Can I call an adjacent cell with an other way or must I use C_F0 ?
Old   March 28, 2012, 14:10
banty
banty is on a distinguished road
In Micro (dudx = C_U_G(c0,thread)[0]) thread is the cell thread not face thread. The cells on either side of a face may or may not belong to the same cell thread. If a face is on the boundary of a domain, then only c0 exists. ( c1 is undefined for an external face). Alternatively, if the face is in the interior of the domain, then both c0 and c1 exist.
There are two macros, THREAD_T0(t) and THREAD_T1(t), that can be used to identify cell threads that are adjacent to a given face f in a face thread t.
This may be helpful to u.
banty is offline   Reply With Quote
Old   March 29, 2012, 04:26
Default I understood now !
Thank you very much Banty , I have not seen that when I wrote my UDF.
It works perfectly now !
thank you !
Old   May 14, 2012, 17:03
Default boundary condition problems
moon
moun139 is on a distinguished road
i wrote a udf for a boundary condition with mass fraction ,but when i want to initialize it write me : error: fluent receive fatal .....
i tried keep memory...[yes]
and solve/expert/ save gradient ? to #t
this is my udf
/* my condition is rearanged as ma=map-(D/jv)*(dma/dy)*/
#include "udf.h"
DEFINE_PROFILE(frac,t,i)
real ma=0.0002; /*initialization of mass fraction */
real grad=0.0002;/*initialization of gradient */
cell_t c;
face_t f;
begin_f_loop(f,t)
c=F_C0(f,t);
THREAD_T0(t);
grad=C_YI_RG(c,t,i)[1];
ma=0.000055-0.00002199301*grad;
F_PROFILE(f,t,i)=ma;
end_f_loop(f,t)
please ,help me .
thank you a lot
moun139 is offline   Reply With Quote
Old   May 15, 2012, 06:18
You define noting with the command THREAD_T0(t) in your code.
First you have to define a thread name that we point on it with the command C_THREAD_T0 and after you have to define it.
Then for all command start with "C_" you have to use the cell thread that you have defined (here the name of the thread is "cell_thread". you can choose a shorter name if you want) and not the face thread.
#include "udf.h"
real grad=0.0002; /*initialization of gradient */
cell_t c;
face_t f;
Thread *cell_thread; /* the star is to say that we will point on it */
begin_f_loop(f,t)
c=F_C0(f,t);
cell_thread=THREAD_T0(t); /* the cell thread adjacent to the face thread */
grad=C_YI_RG(c,cell_thread,i)[1];
end_f_loop(f,t)
I hope that helps you.
Old   May 15, 2012, 07:56
Default boundary
moon
Dear tsi ,
thank you for your information,i try it but it write me the same problem ,also i changed solver to density based because it mentioned in UDF manual
'C YI RG can be used only in the density-based solver.'
can another persone help me ?
thx
error.change.b.condition
Use DEFINE_ADJUST change boundary condition liurengtong123 Fluent UDF and Scheme Programming 29 January 14, 2024 00:56
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
UDF, using DEFINE_ADJUST to change a boundary condition Jonas Larsson FLUENT 4 March 21, 2000 18:51
