March 11, 2012, 03:14 |
Dynamic Mesh
Rep Power: 14 |
Hi
I want do modeling that the body move at one direction by layering method from dynamic mesh in FLUENT 6.3. I use the same UDF that be in User's Guide of fluent. There is one problem during simulation of this case, that the behind cells of body do not split correctly and those stretched, while the cells in front of body, colapse correctly. Despite i change the split and colapse coefficients, do not vary in solution. I will thankful everyone that help me for this problem. Regardly |
March 13, 2012, 07:03 |
Rep Power: 14 |
try to put spring factor to 0.0.
March 13, 2012, 22:58 |
Rep Power: 14 |
I use the Layering method in Dynamic Mesh with structural mesh.
Are you tell that i select spring method plus layering method? |
March 15, 2012, 05:04 |
Time plot in fluent
rz
Dear friends
I m working with fluent 6.3 ,I modelled a wave tank in fluent and I want to get time plot about the history of wave elevation at a specified point for example x=7.5,y=0.5 (in fluent I accentuate this matter again) in a wave tank with these dimensions: L=15m, H=0.8m for a detemined time domain which is smaller than wave tank modeling time domain. if any friend know, plz guide me and give me the tips and tricks about it. With kind regards. |
March 16, 2012, 03:50 |
Rep Power: 14 |
it worked?
March 29, 2012, 11:48 |
tracking water elevation in NWT
rz
what s the meaning of selecting sum in "define surface monitor" for "Phrases" , "volume fraction" . I have a 2 phase domain, primary phase is air and secondary phase is water. I am going to track surface changes for water, in internet i read that I have to select sum when i intoduce monitors/surface/surface monitors/define surface monitor.
my case is a Neumerical Wave Tank. please help me. |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Incylinder dynamic mesh with volumetric reaction | mas | FLUENT | 4 | May 3, 2012 10:22 |
dynamic mesh on a hexa grid | Manoj Kumar | FLUENT | 0 | August 21, 2007 07:41 |
Dynamic mesh + grid adapt = Crash! (Files included | BillH | FLUENT | 4 | July 24, 2007 15:31 |
