Home > Forums > FLUENT
Which Global remeshing technique to use?
Old   March 30, 2012, 10:42
Unhappy Which Global remeshing technique to use?
AJ
akhi2908 is on a distinguished road
I am trying to solve a simple transient fluid flow in which fluid is flowing over a substrate ("wall" at the bottom) and its free surface is coming in contact with a curved roller surface which is not moving [Refer to figure: Slide_1] After a few time steps it is observed that the fluid stacks up at one of the free surfaces and there is no deformation of the mesh below the roller (curved surface) as now fluid enters the gap between the roller and the substrate [Refer: Slide_2]. The simulation fails to converge as the other meshes are distorted further.
Please help me understand what needs to be done to make the fluid flow through the gap. Thanks!
akhi2908 is offline   Reply With Quote
Old   March 31, 2012, 11:55
AJ
If any body has any hint on why it might not be working please comment. I have tried all I could bt still cant change result.
Old   January 25, 2013, 05:23
natalie is on a distinguished road
Hi, akhi!
I'solving practically the same problem? Have you dealed with it? Any ideas?
natalie is offline   Reply With Quote
Old   January 25, 2013, 12:39
AJ
Hey natalie
I needed to split the domain into many parts, mesh them separately and then define as one domain. Also, the boundary conditions on the free surface needs to be selected carefully.
Old   January 25, 2013, 17:17
but how have you made these edges between two zones not to go upstairs? and did the interfaces between different domains work properly?
thanks for your reply
Old   January 25, 2013, 17:31
AJ
Once the setup was defined as a single body, there wasn't any problem of flow b/w two domains. I think there might be something wrong with the boundary conditions. Try increasing the slip on the roller. Playing around with the setup a bit might give you more ideas.
Old   January 26, 2013, 11:46
Thanks for your help!
Thread Tools
Trackbacks are On
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
[ANSYS Meshing] [POLYFLOW] Which Global remeshing technique to use? akhi2908 ANSYS Meshing & Geometry 1 March 31, 2012 11:59
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
