Home > Forums > FLUENT
particle-affected turbulence
Old   March 30, 2012, 15:34
Default particle-affected turbulence
Domenico
doronzo is on a distinguished road
hi
i was wondering if the DPM turbulent kinetic energy source and the turbulent dissipation source appearing in the post-processing (e.g. contours) of k-epsilon turbulent and DPM calculations can be considered the same as the last terms appearing on the right hand side of the k-epsilon equations of multiphase model (e.g. k-epsilon dispersed).
if yes, the only difference between the two would be that the first calculates the effect of particles on k and epsilon in post-processing, whereas the second accounts for it from the calculation start (e.g. it's actual part of the solution), correct? this probably because the first neglects the particle volume fraction, which can be calculated only in post-processing through DPM-concentration (as DPM-concentration/particle density, which would affect the turbulence), whereas the second accounts for it in all governing equations.
p.s. in the fluent manual list of parameters those source terms are absent, but for example the momentum source is present
regards
doronzo is offline   Reply With Quote
Thread Tools
Trackbacks are On
Turbulence postprocessing Mohsin FLUENT 0 September 19, 2011 21:05
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
ONSET OF TURBULENCE ON CORIOLIS AFFECTED FLOWS?? Carl CFX 2 May 8, 2007 03:32
