Run multiple problems in batch mode.
Old   April 10, 2012, 09:18
Default Run multiple problems in batch mode.
tsram90 is on a distinguished road
I am stimulating combustion in a IC engine. So I want to run different cases with different injection timings. I can create different sets of problems with individual msh, cas, dat and pdf files. I want to run them in my College lab. So want a way to do this in batch mode. If I set it and give a go all of these should run one by one until all are finished.
tsram90 is offline   Reply With Quote
Old   April 10, 2012, 17:17
Lucky
You need to write a journal file using TUI commands to give fluent all the instructions that it needs. The file itself can be made in any text editor (notepad).
LuckyTran is online now   Reply With Quote
Old   April 10, 2012, 22:27
Do you have such a sample journal file I can take a look at? Just to see how its to be written..
My Id is sankarram90[at]gmail[dot]com
Thanks
Old   April 10, 2012, 22:35
Lucky
Thanks
Here is a journal file I used some time ago to set all the boundary conditions for a simulation. I had to rename as a .txt file to attach, make sure your actual file is a .jou
the .jou is only a file extension, it is a plain text file exactly the same as a .txt
to iterate you need to use something like
solve/iterate 1000
*Note there are abbreviations for some commands. The first line "rc" is abbrv for read-case. Many of these abbreviations exists, if you don't know them that's fine. The easiest way to find a command (aside from reading the fluent help file) is to press the return/enter key into the TUI. A list of all possible commands will be printed. This is a good way to learn when and what to type. Simply write out the same commands into a journal file and save it and you are all set to go. I use "/" slash marks to remind myself that there are groupings, but you can just as easily erase all the slashes and replace them with empty spaces and the journal will run fine.
Old   April 11, 2012, 04:07
solve/iterate 1000
Thanks a lot. I will get back soon.
Old   April 11, 2012, 04:45
kingjewel1 is on a distinguished road
It looks like you have already set up your case files etc.
your journal file should not look any more complicated than this:
file read-case-data first_case_filename.cas.gz  # read in .cas and .dat files
sol it 10000
wd first_case_filename.dat.gz yes
file read-case-data second_case_filename.cas.gz yes
sol it 10000
wd second_case_filename.dat.gz yes
exit yes
kingjewel1 is offline   Reply With Quote
Old   April 11, 2012, 05:08
sol it 10000
sol it 10000
exit yes
Three things on this kingjewel
Whats filename.cas.gz?? I have to read cas file and dat file. But no .gz files( is it for linux? I am using win 7)
I am using transient conditions. So I have to give timesteps and no. of iterations per time step How do I adjust this? sol it 10000
I want to make solution animations of files. They are not saved in cas, dat files. I have to define them each time I run the file. How can i add them to journal file?
Thanks
Old   April 11, 2012, 05:46
Thanks
the .cas.gz is a compressed format using gzip. Fluent on windows 7 will handle that fine.
sol dual-time it 10000 20 # iterates unsteady  10K 20 its per timestep.
Your best bet is to save images every timestep rather than an animation. You need to look up TUI Fluent documentation for that.
Old   April 11, 2012, 07:47
I had used saving images at first but I could not get commands for everything. I have been checking for commands on temp, pressure etc. Animations are faster, more customizable. And you can create pics or videos from the output files.
use batch mode to run an unsteady case PaulineP FLUENT 9 April 4, 2019 08:18
Batch Run with Initial values file krrishcfd CFX 1 July 28, 2011 02:35
Star-ccm+ batch mode on SGE Karl Jensen Siemens 0 February 4, 2009 15:54
fluent stops batch mode on error Ralf Schmidt FLUENT 1 March 1, 2008 10:35
Prosurf in batch mode Dhruv Siemens 1 September 19, 2005 18:02
