Journal file clicks buttons but doesn't write values, why?
Old   April 1, 2012, 04:34
Default Journal file clicks buttons but doesn't write values, why?
kingjewel1 is on a distinguished road
I have recorded a journal file with my case set-up such as boundary conditions etc. When I read it in again, it doesn't actually change the values of what it recorded.
E.g. I would like to change a boundary inlet velocity from 1 to 2m/s, I can see it opening the window but it doesn't change the value.
(cx-gui-do cx-activate-item "NavigationPane*Frame1*PushButton7(Boundary Conditions)")
(cx-gui-do cx-set-list-selections "Boundary Conditions*Frame1*Table1*Frame1*List1(Zone)" '( 21))
(cx-gui-do cx-activate-item "Boundary Conditions*Frame1*Table1*Frame1*List1(Zone)")
(cx-gui-do cx-activate-item "Boundary Conditions*Frame1*Table1*Frame2*Table2*Frame4*Table4*ButtonBox1*PushButton1(Edit)")
(cx-gui-do cx-set-real-entry-list "mass-flow-inlet-5-1*Frame4*Frame1(Momentum)*Frame1*Table1*Frame14*Table14*RealEntry2(Y-Component of Flow Direction)" '( -0.566))
(cx-gui-do cx-set-real-entry-list "mass-flow-inlet-5-1*Frame4*Frame1(Momentum)*Frame1*Table1*Frame15*Table15*RealEntry2(Z-Component of Flow Direction)" '( -0.1516))
Any ideas why this might be happening?
Regards,
kingjewel1 is offline   Reply With Quote
Old   April 2, 2012, 21:03
Lucky
No ideas, I've never used the recorder.
But your commands are very basic, you can easily accomplish them using the TUI commands (well, all commands can be entered into TUI, but yours are not difficult at all to implement). I recommend doing that rather than wasting time debugging.
Old   April 3, 2012, 04:30
delaneyluke is on a distinguished road
If you want a report of some values through a journal, use the write to file option in results report. Make sure you first create a blank file and then append to that while recording your journal.
Regards
Luke
delaneyluke is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
