April 16, 2012, 11:42 |
Pressure outlet condition is ignored
Rep Power: 14 |
I just found, that for my rotating case (moving reference frame) the intended gauge pressure (-1000Pa) is ignored. So, when I check the static pressure I get values from -1400Pa up to +1100Pa (for three outlets, where each have a gauge pressure of -1000Pa). But the heat transfer results seem to be reasonable. Also, the mass flow rate at the outlets is almost the same as in the non-rotating case (gauge pressure of -1000Pa is achieved at all outlets).... Anyone recognized the same? |
April 16, 2012, 12:11 |
Rep Power: 14 |
I guess it's because of "Radial Equilibrium Pressure Distribution" ....
.... but still the first outlet of the different outlets-rows have more or less with the same distance to axis of rotation .... |
simple model, difficult outlet | Eric | CFX | 7 | May 23, 2014 08:13 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
Using pressure outlet BC | Shreyansh | FLUENT | 0 | November 5, 2010 14:57 |
Natural Convection (Operating Pressure condition) | Andrew Tress | FLUENT | 1 | July 3, 2006 18:27 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
