April 1, 2012, 21:34 |
Drag monitor
can anybody tell me why my Cd, and Cl monitor doesnt work? I cant monitor them like its been said in this forum
I create Cd and Cl monitors but they dont show anything |
April 2, 2012, 13:47 |
http://www.youtube.com/watch?feature...nD180ls#t=310s
That sums it up for a general external flow case, same principles apply for internal or any other kind of flow. Pick a wall, specify a direction vector, print/plot/write. Done. Ehm, yes.. and the Reference values. Those are used to actually calculate the values for the monitor. Basic procedure of setting the reference values can be seen here: http://www.youtube.com/watch?feature...oomxjc8#t=459s |
April 2, 2012, 14:48 |
well i do the same procedure but it doesnt work
it shows NOTHING |
April 2, 2012, 16:06 |
I have no idea then. Go through the checklist of all the settings, because if a force is being calculated and if you have reference values set up then the monitors should work. So, try to do a force report in the direction of the drag and lift force. If that doesn't work than your problem is outside my domain of knowledge :P
Pressure drag, friction drag and total drag? | Cheng | CFX | 9 | January 26, 2024 13:46 |
Lift and Drag Monitor Point Values Converging to Zero | Josh | CFX | 24 | May 9, 2011 10:38 |
Force vectors for drag during sweeping motion | aamer | FLUENT | 0 | April 18, 2011 08:17 |
Monitor drag residual? | jack1980 | FLUENT | 0 | August 27, 2010 08:43 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
