Home > Forums > FLUENT
3d & 3ddp
Old   April 3, 2012, 04:19
Default 3d & 3ddp
pazhouhesh.m.j is on a distinguished road
Dears,
Would you please,tell me what is the difference between 3d & 3ddp in fluent?
The results i got from 3d & 3ddp are different,I mean the difference between them are large.So which results is reliable? or are the 3d results wrong?
Sincerely,
Pazhouhesh
pazhouhesh.m.j is offline   Reply With Quote
Old   April 3, 2012, 04:58
karthik
kitrax is on a distinguished road
3d results are single precision floating point numbers and 3ddp are double precision floating point numbers. You normally use double precision in a Fluent solver.
It works like this:
In single precision: This is a binary format that occupies 32 bits, has a precision of roughly 7 decimal places.
In double precision: occupies 64 bits, has a precision of 16 decimal places.
The main idea you have to take from this is that over a series of iterations, the errors in single precision (3d) could be significant, hence your 3ddp is the solution you should use
Hope this helps, if it does, increase my rep power B)
K
kitrax is offline   Reply With Quote
Old   April 3, 2012, 05:04
Dear,
There is not any error in my problem (both 3d & 3ddp),only a big difference is in the results.So does it mean that ,3d of fluent does not work properly?
Sincerely,
Pazhouhesh
Old   April 3, 2012, 05:34
karthik
Well depending on the number of iterations, I would think 3d is not suitable, if you have a very coarse mesh, I think 3d would be fine. Though for a fine mesh, the error of 3d is carried forward through each iteration therefore leading to a difference between 3d and 3ddp.
What you can do is run your system with a few iterations with each precision and compare the 2 numbers, though I would say if you have already done 3ddp just stick with it
Btw what are you studying?
Old   April 3, 2012, 10:29
Lucky Tran
LuckyTran will become famous soon enough
Just use double precision. There is no reason not to, it is standard nowadays. The difference between single precision and double precision should be hardly noticeable, but just use double precision. It is outright superior.
If the solution is converged, the number of iterations should not affect the accuracy of the single precision vs double precision in the sense of the error being carried forward (unless the simulation is transient). For steady state solver there is no difference, except in the machine precision. i.e. we define convergence based on the solution value and not on the number of iterations that have passed.
Old   November 11, 2012, 13:43
Default About double precision in piecewise polynomials
Abhijeet Shrawage
ashrawage is on a distinguished road
Hello there,
I was just hoping you guys would know about how to increase the decimal places in the piecewise polynomial box where you enter the coefficients for your nth order equation for predicting material properties.
In my case i am using Double precision but for some reason the coeff. are getting rounded off and believe it or not; that reduction in the decimal places messes up my property prediction big time! (i plotted curves using MATLAB and saw the difference)
Please let me know how can I increase the decimal places in the piecewise polynomial boxes
thank you
Abhijeet
ashrawage is offline   Reply With Quote
Old   November 11, 2012, 13:44
Default Images
Abhijeet Shrawage
I have attached the matlab vs fluent images for specific heat
Thread Tools
Trackbacks are On
parallel mode failure in 3ddp but not in 2ddp ak6g08 FLUENT 1 September 22, 2009 06:56
parallel mode failure in 3ddp but not in 2ddp ak6g08 Fluent UDF and Scheme Programming 0 September 22, 2009 06:16
Parallel processing with 3ddp Error Kartik FLUENT 0 February 20, 2009 15:57
when use 3ddp? Txema FLUENT 3 February 21, 2007 17:11
about 3ddp &3d zwdi FLUENT 2 April 18, 2004 14:36
