Reversed flow in Vertical axis wind turbine
Old   April 17, 2010, 00:17
Default Reversed flow in Vertical axis wind turbine
Anonymized_JL1 is on a distinguished road
I am working on my thesis that involves a 2D simulation of a Vertical axis wind turbine. I first made a rotating mesh surrounded by a stationary mesh in ICEM CFD and then applied periodicity in FLUENT. I got it rotating in Fluent but getting a reversed flow at the Pressure outlet. can anyone pls help me out with this problem? I tried to play with the backflow turbulent intensity and viscosity ratio but ended up with the same problem again.
The inner circle (Wind turbine with 3 airfoils) is Rotating at 1500 RPM counter-clockwise and outer rectangle is a stationary farfield. there are 2 zones Far_surface.1 (stationary zone) & rotor_surface.1 (rotating zone). operating pressure is set to be 1 atm.
I can even email my case/data file if somebody is interested to have a close look at the problem.
Thank you so much in advance
Anonymized_JL1 is offline   Reply With Quote
Old   August 25, 2010, 18:30
Steve Hansel
hansel is on a distinguished road
You have probably solved your problem long ago, but I thought I would make a suggestion anyway. I do 2d VAWT simulations in openfoam and for a 1m diameter turbine, I have to make the wind tunnel 20m x 20m or back pressure in the tunnel really affects the results. I'm sjh7132 on YouTube if you want to see some of my work.
hansel is offline   Reply With Quote
Old   April 11, 2012, 04:13
kid
cfdkid
kid is on a distinguished road
@Hansel
Seen your work on youtube. good work.
Are you still in touch with OpenFOAM?
Seek your suggestions on implimenting VAWT model for blades of 1 meter length.
Regards
CFDkid
kid is offline   Reply With Quote
Analyses and Design of Wind Turbine Blades, please help!!! heavymag Main CFD Forum 7 April 13, 2012 17:51
Pressure Drop/Porous Media within Shrouded Wind Turbine Simulation joshdsouza FLUENT 0 March 3, 2010 19:02
Reg - Vertical Axis wind mill analysis ADAIKALARAJA Siemens 4 June 3, 2009 03:23
Angular velocity in wind turbine simulation vanni Main CFD Forum 1 May 18, 2009 12:03
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
