April 3, 2012, 10:53 |
need help in engine simuation
#1 | |
malki
Rep Power: 16 |
April 3, 2012, 11:12 |
malki
Rep Power: 16 |
eany body help
April 4, 2012, 21:13 |
YH Tan
Rep Power: 17 |
Have you add sliding interface on this line?
Herntan, Add Reputation if I am right |
April 4, 2012, 21:15 |
YH Tan
Rep Power: 17 |
Have you add sliding interface here?
April 5, 2012, 01:43 |
Maxime Perelli
Rep Power: 41 |
post a picture of your model without mesh, and display which edges are set as rigid body, interface, stationary
give also the link of your tutorial
In memory of my friend Hervé: CFD engineer & freerider |
April 6, 2012, 08:14 |
malki
Rep Power: 16 |
hallo hentan ,tanks for you answer ;for the line , yes i did sliding interface , i think the probleme is in this line or surface , and i no know how to do
http://www.cfd-online.com/Forums/att...1&d=1333714432 you can see there is two diffirent mesh , how to create a layering zone of sliding mesh ? Last edited by malki; April 6, 2012 at 08:49. |
April 6, 2012, 08:25 |
malki
Rep Power: 16 |
hello max , tank you for your answer i will give you the tut http://cfdcomputing.com/documents/fluent_tutorial3.htm
http://hpce.iitm.ac.in/website/Manua...ug/node458.htm Last edited by malki; April 7, 2012 at 10:52. |
April 12, 2012, 23:49 |
so
malki
Rep Power: 16 |
there is no answers, i don't understand , eanybody put an idea for this
Plz help me "creation IC engine Geometry" | khalaf | FLUENT | 8 | September 28, 2016 01:10 |
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) | kelvinlim | Main CFD Forum | 2 | January 26, 2012 22:19 |
meshing of two-stroke engine in gambit | ravi | FLUENT | 2 | January 18, 2012 01:14 |
Need help for IC engine analysis in basic level | tsram90 | FLUENT | 0 | November 3, 2011 06:57 |
Boundary Conditions for aircraft engine in Fluent 6.3 | Tareen | FLUENT | 0 | July 20, 2011 00:05 |
