Dynamic Meshing Fluent
Old   April 18, 2012, 02:24
Default Dynamic Meshing Fluent
tiho_bg is on a distinguished road
Hi
I am new in Ansys. I am using Ansys 13. I would like to model a dynamic mesh. Could someone help me to move a particle in a liquid environment using only fluent if it is possible. If there is a tutorial about this please send it.
Thank you
tiho_bg is offline   Reply With Quote
Old   April 18, 2012, 06:55
delaneyluke is on a distinguished road
Why do you need dynamic mesh to move a particle in a liquid env?
You don't. Try using the multiphase models available.
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   April 18, 2012, 11:29
Thank you for your answer. I have tried to move a particle in a liquid environment without using dynamic mesh but without success. I am using DesignModeler to create the geometry. I am using Add material->freeze operation to create a cube (air) and a sphere (water) inside the cube. Then I use multiphase approach creating two phases air and water but during the calculation I can not see the motion of the particle. I have made a mistake but I don't know where.
Dynamic meshing of impeller using fluent shadyenany FLUENT 6 September 22, 2011 16:56
Dynamic mesh in Fluent to study tire in contact with road surface lihuang FLUENT 10 March 8, 2011 10:21
Dynamic Meshing Literature oxidising agent ANSYS Meshing & Geometry 3 November 20, 2009 14:58
dynamic meshing option arehman Main CFD Forum 4 June 27, 2004 02:55
Dynamic Meshing James FLUENT 0 May 31, 2004 07:27
