Home > Forums > General Forums > Hardware
Optimal configartion
Old   June 9, 2013, 04:46
Default Optimal configartion
dr.sonic is on a distinguished road
I know there are many threads with similar subject, but I did not find the right one.
My institution got some well funded project, and they want to by the computers for cfd, mainly for modeling the atmospheric pollution. The main programs which we plan to use are ANSYS CFD, AUSTAL2000 and ISC3View.
The budget for the equipment is 40000€. Can you suggest me what would be the best option to buy?
They want to buy 20 computers (2000€ each, with accent on the processor), and connect them to work in parallel mod. Is it better to buy some machines with Quadro cards, and let the GPU do all the work? Or even some system with few Teslas?
dr.sonic is offline   Reply With Quote
Old   June 9, 2013, 16:33
I found some answers in this thread: http://www.cfd-online.com/Forums/har...rkstation.html
So, it seems that it is not wise to invest in Tesla, or other GPU based systems. Also, first I need to know what licence we will be purchasing.
Old   July 8, 2013, 04:08
I have few more days to assemble the configuration. Should I aim for Haswell processors? How important is processor cache?
Is this i7-3930K better than this i7-4770K?
That i7-3930K is only processor with 4 memory channels that I can find.
Old   July 8, 2013, 15:04
Ok, here is the configuration.
CPU: LGA1150 Intel® Core™ i7-4770K
MB: LGA1150 Z87 ASUS Z87-PRO
VGA: GeForce GTX760 ASUS OC 2GB/DDR5
MEM: Kingston HyperX Beast (T3) - 32GB Kit* (4x8GB) - DDR3 2400MHz CL11 Intel XMP DIMM
SSD: SATA3 256GB Samsung 840 Pro Series 540/520MB/s
POW: 850W Chieftec BPS-850C2, Nitro II
With monitor, case, and few other things it is about 2000€. What do you think? I think that processor is the weak link, it has only 2 memory channels.
There should be 20 of those computers, all working in parallel.
Edit: In the meantime I found this processor , it has 4 memory channels .
Old   July 9, 2013, 13:08
Should I aim for the ECC memory?
Old   July 11, 2013, 08:58
Erik
evcelica is on a distinguished road
Which interconnects do you intend to use to network the computers?
Why 20 at $2000 each, why not 10 at $4000, or even 4 at $10000. Do you just want the most capable cluster possible?
And yes, the 3930K should be about 35-50% faster than the 4770K for CFD.
ECC memory would only be supported on server level processors like XEONs, but it is not really needed for CFD and it is slower and more expensive the non-ECC.
evcelica is online now   Reply With Quote
Old   July 11, 2013, 16:26
I dont know that yet.
Because it is defined that way in the project proposal two years ago, and I was not involved in the writing of that project back then
Ok, thanks for help.
Hard problem in simple a rectangle: UDF not optimal? Nano_Cryo FLUENT 3 November 22, 2011 05:23
What is the optimal (economically and user friendly) CFD software for my application? Rame Main CFD Forum 0 August 10, 2009 05:30
optimal control of fluid ztdep Main CFD Forum 0 April 25, 2007 22:12
How efficient is optimal SOR compared with other solvers? Wolfgang Schmidt Main CFD Forum 1 March 13, 2000 09:09
Optimal solution for pipeline Rashid Faizullin Main CFD Forum 1 May 18, 1999 03:07
