December 20, 2011, 00:03 |
Slow case loading on parallel fluent
I am new to fluent. However, I just need to do some simple simulations so I am using a consumer PC. Recently I am running Fluent on a single PC i7-2600 with 12GB(4+4+2+2) memory. I plan to use the 4 cores (8 threads), the solver works as expected, but the case loading and writing are quite slow. I am not sure if these is any hardware limits for it. The case loading/writing works very smooth and fast in the serial mode. It has totally 55180 nodes in the case file and each computing node has about 5800 cells. I appreciate if someone can point me out if there is any mistake. Thanks, |
December 20, 2011, 13:41 |
#2 | |
Vieri Abolaffio
First of all your pc has only 4 cores, you see 8 cores because of the hyperthreading. As cfd codes are effectice in filling up the computational power, it would be better to turn ht off and use just 4 cores. The slow loading time could be caused by a slow hd or network, if you are accessing ddata somewhere else. |
December 20, 2011, 14:02 |
#3 | |
Thank you sail. I turned off the hyperthreading and the case loading is much faster than before. But it is still not as smooth as loading in serial mode. I am reading case file from hard disk, which is 7200rpm. Will this be a problem? However, my network is only 100mb Ethernet. Will it access network frequently during the case loading. I think it shall use shared memory.
December 21, 2011, 15:19 |
#4 | |
duri
Never use threading it always limits your processing power. Its good only for multi-threading applications like games |
Floating point exception during parallel mode of fluent | aamer | FLUENT | 10 | May 16, 2019 09:49 |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Problem using parallel Fluent | Gustavo | FLUENT | 0 | June 27, 2004 23:12 |
