-   -   Simulating square cylinder using cartesian grid? (http://www.cfd-online.com/Forums/main/10009-simulating-square-cylinder-using-cartesian-grid.html)
zonexo October 4, 2005 04:15
I currently 've a FVM navier stokes code which uses cartesian grids. Can I simulate flow past a square cylinder using this code? Will the cartesian grid pose any problem?
If can, does it mean that I need to ignore those cells which are inside the cylinder?
Thank you.
ramp October 4, 2005 04:33
Re: Simulating square cylinder using cartesian gri
Yes, you can solve the square cylinder problem with the Cartesian grid. While solving, ignore the point which are inside the square cylinder and impose the no-slip boundary conditions at the surface of the cylinder.
The following reference (and reference therein) will give you enough details for this problem:
# A. K. Dhiman, R. P. Chhabra, V. Eswaran (2005), Flow and Heat Transfer Across a Confined Square Cylinder in the Steady Flow Regime: Effect of Peclet Number, International Journal of Heat and Mass Transfer, 48, 4598 - 4614.
# A. Sharma and V. Eswaran, Heat and fluid flow across a square cylinder in the two-dimensional laminar flow regime, Numer. Heat Transfer Part A 45 (2004), pp. 247"269.
#A. Sharma and V. Eswaran, Effect of adding and opposing buoyancy on the heat and fluid flow across a square cylinder at Re = 100, Numer. Heat Transfer Part A 45 (2004), pp. 601"624
# A. Sharma and V. Eswaran, Effect of channel-confinement on the two-dimensional laminar flow and heat transfer across a square cylinder, Numer. Heat Transfer Part A 47 (2005), pp. 79"107.
# A. Mukhopadhyay, G. Biswas and T. Sundararajan, Numerical investigation of confined wakes behind a square cylinder in a channel, Int. J. Numer. Methods Fluids 14 (1992), pp. 1473"1484.
# A.K. Gupta, A. Sharma, R.P. Chhabra and V. Eswaran, Two-dimensional steady flow of a power law fluid past a square cylinder in a plane channel: momentum and heat transfer characteristics, Ind. Eng. Chem. Res. 42 (2003), pp. 5674"5686.
# A. Sohankar, L. Davidson, C. Norberg, Numerical simulation of unsteady flow around a square two-dimensional cylinder, in: Proceedings of the 12th Australian Fluid Mechanics Conference, Sydney, Australia, 1995, pp. 517"520.
zonexo October 4, 2005 06:39
wow, ramp, where did u find all that info within such a short time?
Thanks you very much!
Jim_Park October 4, 2005 15:45
You might also check the article in Scientific American, probably in the 60's. It's by Frank Harlow and Jacob Fromm. They used stream function - vorticity.
This was certainly one of the earliest expositions of computational fluids to the scientific community.
zonexo October 10, 2005 06:14
hi, i'm in the process of implementing the BC. if i ignore the pts(cells) inside the sq. cylinder, i've 3 options -
1.i exclude the cells from the sys. of linear eqns and solve it, but the numbering of cells will be quite difficult
2. i include them in the sys. of linear eqns and solve it, but will that cause instability such as 0/0?
3. i include them in the sys. of linear eqns, assign an arbitrary value to center coefficient of the eqn (along main diagonal) and and solve it
Is the 3rd option the best? or is there some other better options?
thanks
ramp October 10, 2005 08:12
I think the first option is good... anyhow u need to define the location of cylinder and the cells inside the square cylinder... and also it is not as such difficult in Cartesian grid... U directly know the coordinates numbering of the sqaure.
