Implementation of Periodic Boundary Condition
Like Tree6Likes
Old   April 26, 2012, 20:04
Chris DeGroot
cdegroot is on a distinguished road
Hmm... so this is not your standard periodic problem since the outflow and inflow are not in line with one another. I would make two suggestions:
(i) I would suggest simulating two chambers such that your inlet and outlet are in line with one another. I don't believe that the way you have it set up that you can guarantee the outflow at the bottom is equal to to inflow at the top. If you simulate two chambers the geometric periodicity will guarantee periodicity in the flow.
(ii) It sounds like you are coupling the inflow and outflow explicitly; that is you get a certain outflow profile and apply that as a Dirichlet BC at the inlet at the next iteration. Your code will converge much better if you couple them implicitly. However this much easier if you set up the problem as suggested in (i).
cdegroot is offline   Reply With Quote
Old   April 26, 2012, 20:33
Mosi Owa
BMCombustor is on a distinguished road
Thanks for your suggestions. suggestion (i) makes sense and I'm gonna apply it know. About your second suggestion, your right; I am applying Dirichlet BC which is kinda explicit. But how can I apply it implicitly?
BMCombustor is offline   Reply With Quote
Old   April 26, 2012, 20:45
Chris DeGroot
As an example, let's say you were computing the gradient of a quantity PHI on the east face of a volume adjacent to the outflow boundary. To do this implicitly it would be (PHI(1)-PHI(N))/DELTAX, where "1" is the volume adjacent to the inlet and "N" is the volume adjacent to the outlet. So you are treating "1" like it is the east neighbour of "N" and this would be incorporated implicitly into your coefficient matrix. You would then form all of the terms in your equations in this manner, where inlet volumes are treated like neighbours of the outlet volumes and vice versa.
Old   April 26, 2012, 21:47
JMC
DeepElm is on a distinguished road
Can you verify that you are conserving mass? Are you solving a compressible or incompressible system? If it is compressible, then adjusting the pressure is not sufficient for convergence.
DeepElm is offline   Reply With Quote
Old   April 27, 2012, 08:53
Mosi Owa
No, it is incompressible and I do check the continuity to be satisfied.
Old   April 27, 2012, 10:39
leflix is on a distinguished road
Originally Posted by BMCombustor View Post
In my new geometry, my boundaries are 1 as left and N as right. As you can see it in attached file (Geometry.jpg), this is a cavity like problem with one inlet at 1 and one outlet at N. But suppose that this is periodic problem and I am going to have the same chamber (but upside down) immediately after the current chamber. Therefore, the outlet velocity profile for the first chamber would be the inlet profile for the next one i
To my mind the geometry of your problem is not periodic.
If you want to impose periodic boundary condition you should consider your domain twice as it is in your simulation. Check the sketch below, I hope you will understand what I mean.... I think this is the first reason why your simulation doesn't work. Then you will have to consider the pressure drop.
leflix is offline   Reply With Quote
Old   April 27, 2012, 10:43
Chris DeGroot
That is what I was thinking as well. It seems like you definitely need two chambers for periodicity. Thanks for the sketch by the way. That was what I was trying to explain above but was too lazy to draw out.
BMCombustor likes this.
Old   April 27, 2012, 11:50
Yes you got the point Chris ! We agree...
Old   April 27, 2012, 12:52
Mosi Owa
Thanks leflix for the attachment. But I think Patankar solved the same problem and reported his work in:
Kelkar K.M., Patankar S.V., 1987, "Numerical Prediction of Flow and Heat Transfer in a Parallel Plate Channel With Staggered Fins" ASME J. of Heat Transfer; Vol 109, pp 25:30.
cdegroot gave me the same suggestion as you did and I am going to apply it. However, just a couple of minutes ago, I finally got result from my simulation with a single channel. The change I applied was that I first let the code converge with a prescribed inlet velocity (which prescribes a specific mass flow); then I used the converged outlet velocity as the inlet boundary condition and solved the problem again from the beginning. The thing is that if I initialize my flow field with the previous solution result, the same thing happens as before, but if I initialize it as a new problem and with zero velocity and pressure everywhere, it gets converged. I do the procedure over and over until the point that my inlet and outlet velocity difference approached to zero. I also correct my outflow with prescribed flow because otherwise my velocity increases over and over. The only thing is that Re number is a little different from what is presumed.The remedy is to correct the viscosity at any iteration to retain my Re. Now I am checking my result with the result of the paper. Then I will apply two channels side by side to investigate to all the suggestions you guys offered me.
Old   May 1, 2012, 16:38
Mosi Owa
Consider a volume "I" adjacent to the outlet and its periodic neighbour "J" adjacent to the inlet. Instead of taking the pressure at the neighbour of "I" to be P(J) take it to be P(J)+DELTAP. Similarly take the pressure at the neighbour of "J" to be P(I)-DELTAP. DELTAP can either be specified if you know the pressure drop and want to find the mass flow. If you know the mass flow, then find DELTAP iteratively using the method of Beale described in his article "Use of Streamwise Periodic Boundary Conditions for Problems in Heat and Mass Transfer".
I just found out what you meant. Thanks a lot for your help.
Old   April 10, 2013, 00:41
Default Coefficient matrix for Finite Volume method with periodic boundary in x direction
  #31
siyamak
siyamak is on a distinguished road
Help please!
I wrote a 2D finite volume code for a rectangular using Neumann boundary in bottom, Dirichlet boundary at top and periodic boundary in x direction. I get some results and everything seems to be fine other than by results tilted toward right boundary and I'm assuming that is because of NOT applying correct periodic boundary condition. Could you please let me know how to build a coefficient matrix which have periodic boundary in x direction?
I appreciate if anybody can help me with that.
siyamak is offline   Reply With Quote
Old   April 12, 2013, 09:09
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
in x direction, if we have N control volumes. start from 0, to N-1.
where 0 means the left boundary, N-1 means the right boundary.
for control volume 1 ,
if no periodic bc: we have
AP1*\varphi1=AE1*\varphiE+Sp.
the effects from the 0 boundary has been lumped into source term Sp.
but with periodic bc, we have a fictious (N-2) control volume at the left of 1 CV. we have
AP1*\varphi1=AW1*\varphi(N-2)+AE1*\varphiE+Sp.
where AP, AE , AW means the matrix coefficent .
Hope this help, if you get some problem again, please let me know.
siyamak likes this.
ztdep is offline   Reply With Quote
Thread Tools
Trackbacks are On
Periodic boundary condition Arif FLUENT 2 January 17, 2014 07:48
Implementation of a relaxation boundary condition fs82 OpenFOAM 2 December 19, 2011 08:04
Simulating A water bubble in air with periodic boundary condition cubicmatrixist Main CFD Forum 0 October 14, 2010 12:26
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
periodic boundary condition? Sima Baheri Phoenics 5 October 20, 2007 09:20
