fluid/structure interaction(FLUENT/LS-DYNA) help!!
Old   October 6, 2005, 13:13
Default fluid/structure interaction(FLUENT/LS-DYNA) help!!
MAOMETTO
i'm working on a project that deals with fluid structure interaction. the project is to model a volume in GAMBIT and mesh it, export it to FLUENT to simulate a flow on the structure and analyze it, export the pressure loads on the structure to LS-DYNA for deformation simulation and re-import deformed mesh and volume for fluid analysis. so its basically a coupling between programs to do fluid structure interaction(FSI). the problem is i'm working with another student who uses LS-DYNA and i'm using GAMBIT/FLUENT. does anyone have any straight forward procedure to transfer pressure grid from FLUENT to LS-DYNA and then re import deformed mesh from LS-DYNA to fluent??? if you anyone did this simulation before, can you tell me how u did it by a simple example such as a simple solid cube under deformation. thanks
Thread Tools
Trackbacks are On
FSI using cfx and ansys vs ls dyna or dytran HAYATE CFX 1 September 21, 2007 15:11
FSI using fluent and abaqus vs ls dyna or dytran HAYATE FLUENT 2 September 18, 2007 08:16
FSI using abaqus and star cd vs ls dyna or dytran HAYATE CD-adapco 0 September 16, 2007 03:27
question about 3d dyna mesh xuzhang FLUENT 1 November 2, 2004 17:48
PhD...in Fluid/Structure Interaction related topic Aamir Main CFD Forum 5 March 13, 2003 12:05
