Validation issue in CFD
Like Tree2Likes
  • 1 Post By cfdnewbie
  • 1 Post By FMDenaro
Old   April 24, 2012, 03:03
Question Validation issue in CFD
fruitkiwi's Avatar
kiwi
fruitkiwi is on a distinguished road
Hi, Dear all,
I met a deadlock in CFD modelling and wish to listen your advice.
I try to simulate flow past through a cylinder.I manage to let it work.
However, today i am questioned when i present it.
1. How are you going to validate your simulation? different article has their own method to simulate the result, which is a cause and effect. You use different boundary condition from them,it should lead different result.
I am wondering, why i cannot only compare results part and i need to go through a CFD paper from beginning to the end?
I am newbie, critics is allowed in this thread. please.
fruitkiwi is offline   Reply With Quote
Old   April 24, 2012, 03:40
cfdnewbie
cfdnewbie is on a distinguished road
In case your code has been validated (the equations are discretized properly, it converges to the exact solution if you increase the resolution), then there's not much you can do. Check if the physics of the example are set up correctly (things like freestream conditions and such), do grid convergence to get some faith in your results.#
If you are doing the flow over a cylinder, that should be easy to compare with other published results. Check the Strouhal number, if that's close to whats published (Strouhal number is pretty easy to get right), work on to things like lift and drag curves....
hope this helps!
fruitkiwi likes this.
cfdnewbie is offline   Reply With Quote
Old   April 24, 2012, 03:46
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
as previously said, if your code is already validated then you can do your computation ... try to check grid-independence ..
FMDenaro is online now   Reply With Quote
Old   April 24, 2012, 04:20
Thumbs up
fruitkiwi's Avatar
kiwi
Hi, cfdnewbie,
Thank you for your advices.
Then i can let it go and jump into the biofluid field.
Any advice you want to give me before i throw myself into bio fluid dynamics CFD modelling?I heard it sounds terrible.My supervisor said "read as much as you can and validate it, use your cylinder which is similar to blood vessel."
Hi, FMDenaro
thanks.
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
CFD Validation of S809 airfoil. cfd_newbie Main CFD Forum 1 July 6, 2011 02:26
CFD Validation John222 CFX 3 May 8, 2011 08:22
Can we quantify the fruits of CFD? Brady Brown Main CFD Forum 14 December 15, 1999 09:42
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
