discontinuous second derivative
Old   April 27, 2012, 22:24
Default discontinuous second derivative
Peter
new_at_this is on a distinguished road
I am calculating the first and second derivative of a velocity profile. I am using a 3 point centered for the 1st derivative and 5 point central stencil for the 2nd derivative.
For some reason I am getting a discontinuous 2nd derivative but I have a smooth 1st derivative. Could some one explain what is going on?
new_at_this is offline   Reply With Quote
Old   April 28, 2012, 05:50
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
could you post the plot of the original function?
FMDenaro is offline   Reply With Quote
Old   April 28, 2012, 10:44
Peter
here is the original velocity profile that was calculated from my cfd code. I am trying to find the inflection points in the profile
http://i1118.photobucket.com/albums/...g/velocity.jpg
1st derivative
http://i1118.photobucket.com/albums/...zhang/1der.jpg
2nd derivative
http://i1118.photobucket.com/albums/...ang/2deriv.jpg
Old   April 28, 2012, 12:29
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
What are you doing near the boundary for the 5 point stencil?
cdegroot is offline   Reply With Quote
Old   April 28, 2012, 12:39
Peter
I am using the following formulas for the boundary point and the first interior point. I have also calculated the 2nd derivative with the 3point central scheme and my main problem is that it is showing an inflection point near the boundary of the flow but I do not expect that to be there.
f''_j = \frac{11f_{j-1}-20f_j+6f_{j+2}+4f_{j+2}-f_{j+3}}{12\Delta x^2}
f''_j = \frac{35f_j-104f_{j+1}+114f_{j+2}-56f_{j+3}+11f_{j+4}}{12\Delta x^2}
Old   April 28, 2012, 12:54
Peter
The velocity profile was generated using a 2D navier stokes code on a staggered grid with dirichlet boundary conditions. I have run the code using parameters where I do not expect to see any inflection points but they still appear near the boundary. This makes me think that it is a consequence of the method I am using and not a physical property of the flow. Is this possible?
Old   April 28, 2012, 13:12
First, if this is the solution in a laminar channel flow, it is not correct, you shoudl have a parabolic velocity profile and a linear first derivative. Furthermore, the second derivative along y is balanced by the pressure derivative along x which is constant
Old   April 28, 2012, 13:50
Peter
This is not channel flow. It is a lid driven cavity problem with both the upper and lower walls moving at RE ~ 500. Also could you elaborate on how the second derivative along y being balanced by the pressure derivative along x affects my problem?
Old   April 28, 2012, 14:59
Peter
So if I run a lid driven cavity flow for a square domain and a Re of 100 and take the velocity at x = 0.5, I find that there is an inflection point near the upper moving wall using a 3 point and a 5 point difference scheme for the second derivative. Conceptually I don't expect this to be there. Is there anyone that can explain what I am seeing?
Old   April 28, 2012, 16:55
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I suggest you to check your derivative (1st and 2nd) function toward some simple case (say a sin function) and perform a grid refinement study to see that everything is fine.
My visual impression is that you kinda used a wrong sign near the boundaries (or for interior points). Also, the first formula you posted (the one for the first interior point) clearly has an error (i'm saying it just because if it is not a typo and you copied it from the code it could help you in find out where the problem is).
According to your second derivative plot, the first derivative one has a first derivative (sorry about this sentence) which is always negative but, according to the image, this does not seem to be the case.
sbaffini is offline   Reply With Quote
Derivative matrix jollage Main CFD Forum 0 September 21, 2011 18:16
can i get pressure derivative in UDF? ruirui389 Fluent UDF and Scheme Programming 4 April 8, 2011 04:12
scalar and its derivative sucker Main CFD Forum 1 April 15, 2008 13:28
Obtaining substantial or partial derivative of vel KRK FLUENT 0 January 10, 2007 12:35
Second derivative with cfx 5.7.1 Alessandro CFX 10 April 21, 2006 10:31
