LES correlation and turbulent energy spectrum
Old   October 13, 2005, 14:21
Default LES correlation and turbulent energy spectrum
Fabian
I want to calculate the turbulent kinetic energy spectrum from my LES data to do one step in the validation process, but I am little bit confused about it.
There are two choices, one is to create a energy spectrum in space, where I have to find a homogenous direction, and the other to create a spectrum in time, where I have to choose a certain point in domain.
The problem is, which variant should I use and esp. which plane for the spectrum in space and which point in a surface-mounted cube simulation?
To calculate the spectrum I have to caculate the autocorrelation or cross-correlation, depending on the choice space/time. There exist an octave/matlab function 'xcorr' which can do that, but I would like to do that without using that function and without the use of FFT.
Would be nice if anybody has an idea!
Fabian
Old   October 13, 2005, 18:07
Default Re: LES correlation and turbulent energy spectrum
sss
For space: invoke Taylor's frozen field hypothesis, For time: simply take FFT of the velocity signal
Old   October 17, 2005, 01:32
Fabian
thanks, do you have an idea which point (time) or plane (space) I should choose for a surface mounted cube calculation. I mean, I could try to find the best point which gives me Kolmogorovs -5/3 slope...
Fabian
Old   October 17, 2005, 05:13
Lionel Larchevêque
In order to have a chance to find a -5/3 slope generally related to a wall-free turbulence at equilibrium, I suppose that the measurement point should be located in the wake and a few cube length away from the aft wall.
Old   October 18, 2005, 02:04
Fabian
Hi Lionel,
thanks for the information. I see how this works.
Greetings! Fabian
Ansys CFX 13, Turbulent flame speed correlation by Bradley ovechkin CFX 0 July 27, 2011 09:49
calculating of velocity auto correlation of solid particles in a turbulent flow mazdak Main CFD Forum 0 December 29, 2009 06:34
Can I add a correlation for turbulent Prandtl No. ? ananta Phoenics 3 November 10, 2009 04:35
