Viscosity variation with temperature for gases-
Old   October 19, 2005, 08:54
Default Viscosity variation with temperature for gases-
Kedar
We would appreciate if some one gives us some formula for varation of viscosity for exhaust gases with temperature in the range of 300K to 600K other than Sutherlands formula.
Old   October 19, 2005, 10:01
Default Re: Viscosity variation with temperature for gases
buch
As an alternative to the Sutherland's law, check the power-law : http://www.grc.nasa.gov/WWW/cgns/sid...ViscosityModel
Sincerely, the result will almost be the same, except that the power law should not be used for temperatures higher than 500K ...
Anyway Sutherland's law might be more accurate ...
Good luck
Buch
Old   October 19, 2005, 11:21
Salvador
Use Lennard-Jones potentials. The difference is L-J takes into account the intermollecular forces, do not expcet much differnces in "normal" conditions.
Old   October 24, 2005, 06:43
Kedar
Thank you guys for your help.
Kedar
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pressure temperature variation Dev CFX 0 June 21, 2007 23:01
viscosity variation lakshmanan Main CFD Forum 3 January 28, 2006 04:32
Viscosity via temperature Alexander Starostin Main CFD Forum 0 June 2, 2005 05:44
frict.fact. variation with T dependent viscosity Fred Uckfield Main CFD Forum 0 August 31, 2001 09:52
