COMSOL: Setting up simple optimization problem
Old   May 2, 2012, 07:01
Default COMSOL: Setting up simple optimization problem
Matt
tdh89 is on a distinguished road
Hi all, i have some doubts about setting the COMSOL optimization module.
My aim is quite simple, i should find the optimal value of a variable to minimize the objective equation.
In particular i should set up the parameter C in this equation(which represents the outlet pressure of a laminar flow model):
S=Q*C+po
in order to minimize the following equation:
abs(p-15000)
Where p is the pressure coming out from linear flow model (spf) and 15000 is a reference pressure, both applied to domain.
The algorithm is quite simple, comsol should:
1)assign a value to C
2)estimate the value of domain pressure( coming out from laminar flow model)
3)verify if optimality condition is satisfied, otherwise start again from 1
My doubt is about implementation: which kind of objective should i use (integral objective, probe objective...)? Should i use inequality constraints too?
Best regards
tdh89 is offline   Reply With Quote
Old   May 23, 2012, 03:55
Niklas Rom
niklas.rom is on a distinguished road
C is a control variable. Add the control variable item by right-clicking the Optimization node in the model builder tree on the left. Assuming now that C is a global parameter (and not a local point value or field variable) a Global control variable is should be added. Inequality constraints are only needed of you have other restrictions to the control variable.
abs(p-15000) should be used in an Objective function. Add that feature the same way as above. If p is a point value use Point-> Integral objective. If is field variable on space use boundary, edge etc and Integral constraint.
The best way to get a kick start is to look in the prepared model examples. Search for optimization in the Model Library window’s search field to find the models that use the Optimization Module in the products that your license includes.
Niklas Rom, COMSOL
S=Q*C+po
abs(p-15000)
Best regards
niklas.rom is offline   Reply With Quote
comsol 4, opimization
Thread Tools
Trackbacks are On
Very simple natural convection problem Naseem FLUENT 17 December 15, 2015 11:12
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox Stubby OpenFOAM Installation 8 March 5, 2012 16:12
Help setting up combustor problem Tom FLUENT 0 February 5, 2005 02:20
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 06:19
