May 2, 2012, 10:51 |
Deforming wall profile
Rep Power: 15 |
Hello everyone!
I’m dealing with changing of wall profile due to flow properties. The profile isn’t known beforehand, so it’s part of solution. Water flows in tube, the problem is planar. View of .cas file is attached. Mesh view in general and zoomed in deforming region are also attached. The desired wall profile is taken from the article and picture is attached. To my mind, wall deformation can be estimated according with Wall Shear variable. So, I’ve got several questions. 1. Is it possible to solve such type of wall deformation, using CFX only (I mean, mesh deformation laws and UDFs)? 2. If not, then maybe FLUENT can do it? 3. If neither CFX nor FLUENT can’t do this by their own means, then is the two-way FSI proper decision? 4. Is it possible to estimate contribution of each component of Wall Shear variable in common deformation? (probable functions that I use to deform mesh are attached) Thanks a lot for help! ) |
Display Modes | |
Unsteady Boundary Profile with data file | Arianna | FLUENT | 34 | July 29, 2019 17:35 |
[mesh manipulation] mergeMeshes problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 3 | July 29, 2015 05:15 |
Moving wall with velocity profile | Tobard | FLUENT | 37 | April 9, 2015 10:54 |
[GAMBIT] evaluting meshing and velocity profile near the wall | zandi | ANSYS Meshing & Geometry | 3 | February 18, 2010 16:38 |
Z wall or Deforming Wall | bharath | FLUENT | 0 | October 31, 2003 16:23 |
