Turbulence intensity
Old   April 29, 2012, 05:24
Question Turbulence intensity
LaGurk is on a distinguished road
Hello community,
I do some simulations in an artificial homogeneous isotropic turbulence where k and eps are given. Does anyone know, how to calculate the turbulence intensity out of these values?
Thanks so long.
LaGurk is offline   Reply With Quote
Old   April 29, 2012, 07:29
truffaldino's Avatar
truffaldino is on a distinguished road
You can just take a look at Fluent manual
6.2.2 determining the turbulence parameters
Relationships between the turbulence quantities
e.g. here http://jullio.pe.kr/fluent6.1/help/html/ug/node178.htm
Truffaldino
truffaldino is offline   Reply With Quote
Old   May 3, 2012, 04:27
Thanks for that link. My problem is, that in a homogeneous isotropic turbulence the average fluid velocity is 0? That means I cannot calculate the turbulence intensity with the given formulas. Does anybody know, how to solve my problem. Or maybe I am wrong.
Old   May 3, 2012, 07:16
Could you tell more about details of your simulation?
If you do not have a reference speed, you could derive "reference speed" from the average energy flow per unit mass through the system.
Old   May 3, 2012, 10:53
I am simulating particle collisions using a Lagrangian code. The fluent is just given by k and eps in the domain. The local fluid velocity for particle tracking is calculated using k and eps by a langevin dispersion model. For characterising the turbulence I want to give the turbulence intensity.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
