May 7, 2012, 03:51 |
immersed boundary method of Markus Uhlmann
dishengbin
Hello, everyone.
I’ve tried the immersed boundary method proposed by Ulhmann (Uhlmann, M. (2005). "An immersed boundary method with direct forcing for the simulation of particulate flows.”). I have doubt about the determination of Lagrangian markers (requires ds=dx),the mathematical expressions are in the attachment. Can anybody explain the reason? Thank you very much! |
May 8, 2012, 20:34 |
dishengbin
anybody kowns the reason? thank you in advance
May 8, 2012, 23:06 |
Arjun
Rep Power: 34 |
May 8, 2012, 23:45 |
dishengbin
May 9, 2012, 04:05 |
#5 | |
Arjun
Rep Power: 34 |
But I haven't read the original paper you quote and I do not have access to it. I thought your docx might give me some hints to what you are talking about but I can not open that either. Anyway, if I have to just guess blindly, my guess is that he require ds=dx etc because of ease of interpolation (creating a interpolation function) or ease of marking solid and fluid points. Solid marking is tough and time consuming task if grid is not uniform or if grid is unstructured. |
May 9, 2012, 05:44 |
#6 | |
dishengbin
(i'm not sure whether you can access it) In equation (9b), dv = dx*dy = ds*dx(dy). in 2D case. But in the flow past a stationary circular cylinder, when I use more or less markers, the drag/lift force varies significantly. In some other papers , dv is replaced by ds. So could you let me know the reason? thanks |
immersed boundary method, lagrangian markers, uhlmann |
implementation of the Immersed Boundary Method | mi_cfd | Main CFD Forum | 19 | April 24, 2019 01:24 |
Immersed boundary method (IBM) vs Dynamic meshing | tomyangbath | Main CFD Forum | 5 | April 17, 2009 03:02 |
Immersed boundary method with momentum forcing | Fuka | Main CFD Forum | 1 | February 6, 2006 03:46 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
